ᐅ How can I customize the color of Ikea PAX doors to match my apartment?
Created on: 8 Apr 2019 20:17
Lapau1Hello everyone,
I am planning to customize the color of my Ikea PAX wardrobe doors to harmonize perfectly with the rest of my living space. My apartment has walls in a warm beige tone, light oak wood furniture, and a noticeable mix of muted pastel colors, especially subdued blues and greens.
Since PAX doors usually come in white or cooler color variants by default, I am looking for ways to style these doors to complement the warm and cozy character of my interior.
What techniques, materials, or types of paint would you recommend to individually match Ikea PAX doors to my apartment’s color scheme? I am thinking of options such as painting, applying vinyl wraps, or perhaps other creative solutions, but of course, the result should be durable and relatively easy to maintain.
I appreciate any tips or experiences you can share, especially if someone has completed similar projects and can point out challenges or important details.
pauPierce9 Apr 2019 07:43Hello Lapau1,
First of all, I think it’s great that you are considering the color coordination, as a well-chosen color scheme can significantly influence the overall look. There are several approaches when it comes to customizing the color of your Ikea PAX doors.
I’d be happy to explain a few options along with their pros and cons – maybe this will help you decide:
- Painting: This is the most classic method. You need to sand the doors thoroughly beforehand, as many Ikea surfaces are painted or coated with melamine, which can make paint adhesion difficult. Priming is therefore almost always necessary. Water-based acrylic paints are recommended because they have less odor and fewer harmful substances. Keep in mind that multiple coats and drying times are needed to achieve a rich color result. The downside is the effort involved plus the drying time.
- Vinyl wrapping: Self-adhesive vinyl films are available in many colors and patterns. High-quality films, like those used for furniture or kitchen fronts, are more durable and also offer a scratch-resistant surface. If you choose vinyl, make sure to clean and degrease the surface thoroughly. A disadvantage is that vinyl can be harder to apply on doors with handles or pronounced curves.
- Glazing or staining: If you want to create a wood effect, for example matching your oak wood, you could treat the doors with a thin glaze or stain, provided the material allows it. However, sometimes PAX doors are not made of real wood, so this is not always possible.
- Specialty or textured paints: For an individual touch, you can also use paints with effects or textures. However, you should consider in advance whether these will fit with the rest of your interior.
One more question: Are your PAX doors made of glass fronts, particleboard, or MDF? The effort required can vary depending on the material.
I hope this helps you for now.
pauPierce schrieb:
- Painting: This is the most traditional method. You need to sand the doors carefully beforehand because many Ikea surfaces are either painted or coated with melamine, which can make paint adhesion difficult. Therefore, a primer is almost always necessary. Water-based acrylic paints are recommended since they have less odor and fewer harmful substances. Keep in mind that multiple coats and drying times are required to achieve a rich color. The downside is the effort involved plus the drying time.I think it’s important to also question whether “traditional” is always the best solution. Painting means you commit to that color long-term – with uneven surfaces like melamine, paint can peel or detach.
As an alternative, trying out films or even coverings first could be a good idea since these are reversible and allow easier redesigns later without needing to repaint or sand again.
Additionally, you should really check how the warm tones you choose look under different lighting conditions. Especially with pastel and warm beige tones, artificial or natural light can have a strong effect.
Have you tested the furniture colors in various lighting? Typically, areas near windows feel cooler, while interior spaces with warm lamps appear different.
Without this testing, what seems like the perfect shade during the day might feel completely off in the evening.
Natan schrieb:
Without this test, it’s possible that the perfect shade looks great during the day but doesn’t work well in the evening. Absolutely! I experienced the same with my PAX doors – during the day, the tone appeared nice and warm, but in the evening, under lamp light, it suddenly looked much paler.
I would also recommend not getting too fixated on perfection. Sometimes a slight contrast with the rest of the room works better than a 100% matching color. A bit of tension often creates a more lively effect.
And don’t be afraid to experiment: if you’re interested in a creative solution, magnetic chalkboard paint or chalk paint could be options if you want to make your doors more versatile.
Enjoy your project, and remember: the most important thing is that you feel comfortable in your home.
I believe that a systematic approach helps with customizing the color of Ikea PAX doors:
- First, check the door material (MDF, particleboard, lacquered).
- Choose a painting method that is compatible with the material.
- Obtain paint samples, preferably in combination with the materials of the walls and furniture.
- Test the selected colors on an inconspicuous spot or on a removed inner side.
- Pay special attention to surface preparation before painting: sanding, priming, and selecting high-quality paints.
Personally, thorough preparation has helped me the most to achieve a durable and visually appealing final result.
And if you use adhesive film: It’s better to choose a higher-quality film, which is easier to work with and lasts longer.
