ᐅ Has anyone ever painted the Kallax?
Created on: 5 Sep 2017 13:12
Bauju
I am considering buying a Kallax shelving unit from IKEA and painting it myself. Has anyone here had experience with painting or refinishing a Kallax unit on their own? I am especially interested in the preparation process (sanding, priming), which type of paint works best, and how to make the surface durable after painting. Are there any special tips or precautions to ensure the result not only looks good but also lasts a long time? I would appreciate any advice or personal experiences!
lubla
5 Sep 2017 16:12
Sanding, plastic primer, followed by acrylic furniture paint. A clear coat at the end helps. Strictly observe drying times.
tra_nina
5 Sep 2017 18:02
A small additional note to the previous recommendations: Melamine resin coatings are indeed very smooth and not easy to repaint. It is advisable to use a fine sanding pad or sandpaper with a grit of 220 to slightly roughen the surface without damaging the furniture piece. For priming, I recommend a bonding primer specifically designed for plastics. Afterwards, you can use acrylic paints suitable for furniture. It is also important to use an appropriate brush or a foam roller to avoid brush marks. Sealing with a matte clear coat further increases scratch and impact resistance.
PERON
6 Sep 2017 09:04
tra_nina schrieb:
It is advisable to use a fine sanding pad or 220-grit sandpaper to slightly roughen the surface
Exactly that, I used a sanding pad, which was much more comfortable than sandpaper. This way, the shelf retains its texture without any “attack” on the edges. 🙂
kloreo
6 Sep 2017 10:45
Regarding colors: Always use water-based acrylic paints. Avoid oil-based paints, as they often damage the surface. After painting, allow the paint to dry thoroughly, otherwise problems may occur later.
piBenedi41
6 Sep 2017 11:35
PERON schrieb:
And that way, the shelf retains its structure without any damage to the edges.
I can confirm this. During my first painting, I sanded the edges too aggressively. Although it didn’t harm the shelf, it didn’t look good. So: better to sand carefully and proceed slowly.
Bauju
6 Sep 2017 14:21
Thanks for all the tips so far! I’m still curious whether anyone has applied the paint with a roller or a brush? I’m undecided on what works better for a smooth surface, as brushes often leave streaks and rollers might not reach the corners as well. Maybe someone has had practical experience with this?
