ᐅ How can I easily paint IKEA Hemnes furniture with minimal effort?
Created on: 10 Oct 2020 08:23
RICOFAR
Hello everyone, I would like to paint some of my IKEA Hemnes furniture to refresh their appearance. However, I don’t have the time or patience for extensive preparation and lengthy painting processes. Therefore, I’m interested in how to paint these Hemnes pieces with as little effort as possible without compromising the results. I’m especially looking for advice on simple preparation, suitable types of paint, and tips on how to avoid the need for tedious sanding or priming. What approach would you recommend for someone who expects a good outcome but wants to keep the effort as low as possible?
LuMarcel43 schrieb:
There are very contradictory opinions here.Yes, that’s exactly why I’m asking here. It would be helpful to know if a primer is really necessary and, if so, what type. So, would a solvent-based primer be better, or can you use a water-based one? And would you consider sanding essential, or are there very practical alternatives? My goal is really to keep the effort as low as possible while still achieving a durable result.
sonpar schrieb:
You can also use spray paints that are specially designed for furniture.Could you please explain that in more detail? Which spray paints are those? And what do I need to consider that doesn’t apply when using rollers or brushes?
Spray paints for furniture are convenient because they apply thinly and evenly. It is important to clean the surface beforehand and lightly sand it. Then apply thin layers and allow them to dry thoroughly. Without a primer, the result is often not durable, but renovation sprays with adhesion primer work better.
LuMarcel43 schrieb:
That sounds good, but isn't solvent-based a problem regarding odor and environment?That is partly true; solvent-based primers tend to have a stronger smell and require good ventilation. However, they often perform more reliably on furniture, especially on veneered surfaces.
RICOFAR schrieb:
Would you consider sanding essential, or are there very practical alternatives?Sanding is the simplest way to improve adhesion. Alternatives like bonding primers (also called adhesion promoters) exist, but they are often more expensive and you still need to clean the surface at a minimum. If you want to paint quickly, it’s still best to use fine sandpaper and degrease the furniture beforehand. This is much more effective than just cleaning.
RICOFAR schrieb:
Could you explain that in more detail? Which spray paints are those?For furniture, spray paints with adhesion primer designed specifically for wood and MDF work well. Acrylic-based paints containing adhesion promoters often perform reliably. But be careful: heavy spray application can cause the surface to become uneven.
I also recommend thoroughly cleaning the furniture, then lightly sanding it with fine-grit sandpaper to remove the gloss. After that, apply a water-based primer or directly use acrylic paint. If you want to skip the primer, you can use a 2-in-1 paint with a bonding agent that can be applied directly. This reduces the overall effort.
LuMarcel4311 Oct 2020 08:15RON57 schrieb:
Alternatives like bonding primers (also called adhesion promoters) exist, but they are often more expensive and you still need to at least clean the surface.I agree with that; the price difference is often only justified if you really want to save time. Still, the question remains whether a light cleaning and a 1-minute sanding are always enough for furniture with more complex surface areas or edges. I am skeptical about that, especially since the Hemnes series features detailed profiles. You shouldn’t underestimate the impact on the final result.
I would like to add: For painting, high-quality brushes with short, fine bristles or a foam brush are also suitable to avoid streaks. Rollers often leave slightly textured surfaces when used with glossy paints. If you want to minimize effort, it is best to choose simple types of paint that are not too viscous.
