ᐅ Is it possible to customize the color of IKEA Brimnes furniture?
Created on: 23 Apr 2022 10:17
janon
I am considering customizing the color of some of my IKEA Brimnes furniture pieces to better match my apartment’s interior. My specific question is: Is it possible to personalize IKEA Brimnes furniture with paint, and if so, which methods work best without affecting the functionality or stability of the furniture? I am particularly interested in whether the surfaces can be easily painted, or if other techniques like applying vinyl wraps or adhesive films are practical. It would also be helpful to know if there are any special characteristics of the materials that should be considered when adjusting the color. I look forward to your experience and tips!
Jensson
23 Apr 2022 16:22
Hello janon,
I would like to briefly and clearly explain how a custom painted finish on Brimnes furniture can be done. I will outline the typical steps for painting on melamine-coated furniture:
1. Cleaning: Thoroughly clean the furniture surface with a degreasing cleaner.
2. Sanding: Lightly sand with fine sandpaper (grit 220-320). The goal is to roughen the high-gloss coating.
3. Priming: Apply a primer designed for melamine surfaces, especially for plastic or laminate paints.
4. Sanding again between coats to achieve a smooth surface.
5. Painting: Use acrylic paints or special furniture spray paints.
6. Finishing: Apply a clear coat as a sealant.
A common mistake I often see is skipping the primer, which leads to peeling.
Note: Patience during drying times is crucial, otherwise the surface may warp.
COLEBAR
23 Apr 2022 17:11
In short: Wrapping is straightforward, but not always perfect with Brimnes due to the edges. Painting works well with proper preparation.
Plastic parts: Painting is possible, but preparation is even more important.
Z
zarJody68
24 Apr 2022 09:45
Additional technical information:
The melamine coating on the Brimnes furniture prevents easy absorption of paint, so priming is essential. For films, surface pre-treatment is often necessary (e.g., degreasing and light sanding) to improve adhesion.
Plastic paint is suitable only if it remains flexible, such as special plastic coatings or those based on acetone. Otherwise, you risk cracking and chipping.
In summary, I recommend:
- For durability: painting with proper preparation and appropriate materials
- For temporary color changes: high-quality cast films
Important: Treat the furniture under suitable conditions (dust-free, not too humid).
sonplo
24 Apr 2022 11:02
Jensson schrieb:
Patience is crucial when drying paints; otherwise, the surface may warp.
That is absolutely correct. Additionally, I recommend applying several thin coats of paint rather than one thick layer. This results in a smoother finish and better adhesion.
Regarding plastic handles: a full replacement is often more effective than risking uneven paint results. Some manufacturers also offer affordable alternative options.
Before you start, it’s best to test your materials on an inconspicuous area.
Deandre
25 Apr 2022 08:55
janon schrieb:
Are there maybe specific types of films that adhere better or special techniques to increase durability?
I can add to this: In professional settings, so-called "hot air tools" are often used to soften films and better fit them into corners. This significantly increases durability. For home use, a hairdryer on a high setting is often sufficient. It is important that the surface is absolutely clean and free of grease.
dijan schrieb:
Some people simply replace the handles; there are spare parts available at IKEA or third-party suppliers
That is a very simple and practical alternative. So if you want to change the overall look of your furniture, it makes sense to include the handles as well.
