ᐅ How suitable are Ikea BRIMNES furniture units for self-painting?
Created on: 22 Apr 2021 08:37
pauljeHello everyone, I am considering repainting some Ikea Brimnes furniture myself to give it a more personalized look. I am especially interested in how suitable this furniture is for DIY painting.
I have read that Ikea surfaces are often made of MDF or particleboard with a melamine coating, which apparently is not the best base for painting. Does anyone have experience with how well the BRIMNES series can be sanded, how well the paint adheres, and what the best approach is to achieve a durable and even finish?
In addition to tips on the right type of paint and preparation methods, advice on potential pitfalls or problems when painting would also be very helpful. Thank you in advance for your contributions!
Basically, the melamine coating on BRIMNES is quite durable but also very smooth. To ensure proper adhesion of the paint, I strongly recommend lightly sanding the surface with 240 to 320 grit sandpaper. After that, you should use a special primer, preferably an adhesion promoter designed for plastics.
When it comes to the paint itself, it is important to choose a water-based, abrasion-resistant paint suitable for furniture, such as acrylic or synthetic resin paint. I also suggest applying several thin layers to achieve a clean finish. Don’t forget to allow drying time between coats, as this affects durability.
One more question: Do you plan to use the furniture indoors? And how heavily will it be used? This plays a major role in selecting the right coating.
Hey, this topic really hits home for me! I painted my BRIMNES wardrobe some time ago, and it was quite an interesting process 😅. Thorough sanding was absolutely crucial; otherwise, the paint wouldn’t adhere at all.
I used an acrylic paint afterwards, which held up very well and gave a nice matte finish—just my style. A little tip from me: if you have the time, choose a satin finish paint, as it better hides small scratches. Also, be careful with strong solvents in the paint, since they can sometimes cause furniture to react oddly.
For clarification: BRIMNES is primarily made of particleboard with a melamine coating. This combination is neither very absorbent nor easy to paint without proper preparation.
The pretreatment should include the following steps:
- thorough degreasing,
- light sanding,
- applying an adhesion primer.
The choice of paint is crucial: two-component (2K) paints or special water-based alkyd paints are ideal.
If you want to maintain the same gloss level, be sure to test beforehand.
- light sanding,
lorena schrieb:
One more question: Do you plan to use the furniture indoors? And how heavily will it be used? This plays an important role in choosing the type of finish. Thank you for the detailed advice! Yes, the furniture will be kept indoors, mainly bedroom furniture, so it will be used frequently but without exposure to moisture or extreme stress like outdoor use. Therefore, I can prioritize durability and appearance rather than weather resistance.
Would a water-based acrylic paint be sufficient in my case? Or would investing in a two-component (2K) finish be more worthwhile? How significant are the differences in practice?
