ᐅ How do I maintain Ikea BRIMNES furniture on a daily basis?
Created on: 22 Jun 2024 09:42
potuan
Good morning everyone, some time ago I purchased several Ikea Brimnes furniture pieces, especially cabinets and dressers. Since preserving their appearance and functionality is very important to me, I am now looking for well-founded advice on how to care for these pieces on a daily basis.
I am not just referring to regular dusting, but also the best ways to protect the surfaces from scratches, discoloration, or moisture damage. Are there specific cleaners that are well suited, or should I rather use home remedies? What is the recommended treatment for hinges and drawer slides? And are there any other tips I should keep in mind to enjoy my BRIMNES furniture for a long time?
potuan
22 Jun 2024 16:43
Jukin schrieb:
A little silicone spray or special furniture oil helps to keep hinges and drawer slides operating smoothly.
Thanks for the tip, that sounds very practical. Do you need to apply the spray frequently, or does it last if you do it just once?
Dilen schrieb:
Have you noticed if your furniture is located in a particularly humid environment? That increases maintenance needs and might require specific care.
The furniture is in the living room, where the air tends to be dry in winter because of the heating. In summer, it can get more humid due to open windows, but only temporarily.
Is there any way to prevent damage if slight water stains appear around the edges of the doors? I sometimes clean quickly after cooking when I get close to ingredients or grease.
RENMA
22 Jun 2024 17:29
potuan schrieb:
Is there any way to prevent damage when slight water stains appear on the edges of doors?
Yes, that is possible. The edges, often coated with melamine, are particularly sensitive to moisture. Therefore:
- Wiping off water or grease spots immediately prevents them from soaking in.
- Avoid using aggressive cleaners, as they can damage the protective surface.
- For damp spots on the edges, a dry cloth can help absorb dirt without scratching the surface.
If water exposure happens frequently, the area can additionally be treated with furniture wax, which creates a protective layer and repels moisture.
gasidney
23 Jun 2024 08:12
A tip: Avoid placing hot pots or pans directly on Brimnes surfaces. Heat can damage the melamine coating.
Always use a trivet or a cutting board underneath instead.
Jukin
23 Jun 2024 09:25
potuan schrieb:
Do you need to apply the spray frequently, or does it last after a single application?
You need to apply it regularly, about every 3-4 months, depending on use.
It prevents hinges from squeaking and reduces wear. However, too much lubricant attracts dust, so it’s important to apply it sparingly.
For mechanical parts like hinges, it is more of an ongoing maintenance task.
KAULIS
23 Jun 2024 12:47
In summary, based on material properties:
- Products: Do not use abrasive cleaners or solvents.
- Cleaning: Use a microfiber cloth and a mild soap solution if necessary.
- Drying: It is important not to leave any moisture on the surface.
- Maintenance: Use lubricants sparingly on fittings.
- Prevention: Avoid direct sunlight, heat, or standing moisture.
These measures ensure the long-term stability and appearance of the IKEA BRIMNES furniture.
Dilen
24 Jun 2024 11:06
Here are a few final tips, especially for long-term maintenance:
- For heavier dirt or stains, it is recommended to test a small, inconspicuous area before cleaning the entire surface.
- Avoid placing wet objects on the surface.
- If you have deeper scratches: fine furniture polish can help to touch them up, but use it carefully due to the coating.
Finally, are you already familiar with these measures, or do you also need guidance on the proper use of cleaning products?
