ᐅ Which maintenance products are specifically recommended for IKEA Brimnes furniture?
Created on: 28 Apr 2022 08:43
WOLFMI
I am currently focusing on the best way to care for my IKEA Brimnes furniture series, especially the wardrobes and dressers. Since these are mostly made of particleboard with a melamine-coated surface, I am wondering which care products you would specifically recommend for the IKEA Brimnes model to avoid damaging the surface while providing the best possible protection against scratches, moisture, and everyday wear.
I want to avoid chipping, discoloration, or dull spots caused by the wrong cleaning agents. I am also interested in whether there are special care tips or products tailored specifically to laminate coatings, as regular furniture polish seems potentially unsuitable here.
Who has experience and can provide concrete recommendations, such as brands, ingredients, or types of care products that have proven effective? Perhaps also the differences between cleaning, protecting, and refreshing the surface?
Thank you in advance for your informed advice!
glamo
29 Apr 2022 09:46
A very interesting question you raised, WOLFMI.
Regarding the technology of the Brimnes surface: The melamine coating is a thermoset resin that is seamless and highly resistant to most liquids as well as abrasion. This results in some important details for care:
- The surface is not damaged by water as long as there are no standing water amounts acting for an extended period.
- Common furniture polishes often contain waxes that do not penetrate well into the melamine resin layer and tend to wear off or become blotchy.
- Mechanical cleaning with sponges or abrasive cloths is not recommended, as these can cause micro-scratches and clouding.
Recommended products:
- Specific laminate cleaners with a pH-neutral formula (e.g., water- and surfactant-based products without solvents)
- Possibly a polymer-based care film applied after thorough cleaning to provide longer-lasting protection
It is also important to care for the edge areas, which consist of painted particleboard and are more sensitive to moisture. Edges with clear lacquered sections should therefore be cleaned only with minimal moisture and, if necessary, treated with wood care oil to prevent swelling.
Could you possibly describe if you have any problems with the surface? Do dust, scratches, or pigment stains influence your care decisions?
WOLFMI
29 Apr 2022 10:02
glamo schrieb:
Could you maybe also describe if you have any issues with the surface? Do dust, scratches, or pigment stains influence your choice of maintenance?
Thank you for your detailed explanation! Lately, I have noticed more small scratches and very slight matte spots, mainly on the shelves. In addition, liquid stains sometimes seem difficult to remove, especially if they weren’t wiped off immediately. Fortunately, I haven’t observed any discoloration so far.
Dust tends to accumulate quite quickly due to the matte surface, as it makes dust particles more visible. That’s why, aside from cleaning, a light protective film is very important to me—it should make the surface more resistant to abrasion and also feel more pleasant to the touch.
Your idea of a polymer protective film sounds interesting. Are there specific products or materials you would recommend, or particular points I should pay attention to?
O
ODINFLO
29 Apr 2022 10:27
I need to follow up on this:
glamo schrieb:
Edges with clear lacquered areas should therefore only be cleaned with minimal moisture and, if necessary, treated with wood care oil to prevent swelling.
Where does this recommendation about using wood care oil on lacquered edges come from? I find this concerning because wood care oil can damage the lacquer or be absorbed unevenly.
Does anyone know if IKEA provides specific care instructions for Brimnes edges? These areas are often sensitive, and improper treatment can cause more harm.
I suggest contacting the manufacturer directly or using the official care guidelines. Does anyone have sources or practical experience?
Landontau
29 Apr 2022 11:01
ODINFLO schrieb:
I recommend contacting the manufacturer directly or following the official care instructions.
That’s a good point you bring up. According to the official information from IKEA, the Brimnes series is classified as laminate furniture. The edges are usually finished with ABS edge banding, which is resistant to moisture.
Therefore, I do not recommend applying wood care oil to painted or laminated edges, as this can actually cause unsightly stains and peeling.
For the edges, a dry or slightly damp cloth is usually sufficient. For stubborn dirt, a mild cleaner may help, but it must not be too harsh.
bensau
29 Apr 2022 12:37
SAWYERR schrieb:
If you really want to, you can use a special laminate care product, but usually that's unnecessary.
I agree, but honestly: a little maintenance is okay! 😉 Laminate care products are available in affordable spray bottles. Just spray onto a cloth, wipe a bit, and boom – the surface looks richer and feels smoother.
I like to use products specifically marketed "for coated furniture." Whether it’s Brimnes or other TV units, it doesn’t matter. The important thing is that nothing is sticky or shiny, otherwise it quickly looks artificial.
Just avoid the heavy-duty old-fashioned household polishes; those definitely don’t belong on the Brimnes surface.
koneo
30 Apr 2022 08:56
In conclusion, I would recommend always testing any new care product on an inconspicuous area if you want to use it on the Brimnes surface.
Since the melamine surface can be quite sensitive to solvents, silicones, or waxes, a small test is advisable to rule out any discoloration or streaking.
Additionally, it is best to care for the furniture regularly but in moderation. Applying protective coatings too often can build up and affect the matte finish.
In my experience, a mild laminate cleaner and a dry microfiber cloth work best to maintain a well-cared-for appearance over the long term.
