ᐅ Floor plans for a single-family house, approximately 1,500 sq ft (140 m²), without a basement
Created on: 1 Nov 2016 14:14
stefanvery
Plot size: 439 sqm (4720 sq ft)
Slope: yes, approx. 1.3 m (4 ft) descent across the plot, approx. 0.5 m (1.6 ft) in the house area
Site occupancy index (floor space ratio): 0.35
Floor area ratio (FAR): 0.6
Building window, building line and boundary: see development plan
Border development:
Number of storeys: 2
Roof style: any
Architectural style: any
Orientation: southeast or southwest
Maximum height / limits: 10 m (33 ft) above street curb level
Further requirements
Homeowners’ Requirements
Style, roof type, building type: gable roof
Basement, floors: 1.5 floors without basement, approx. 1.25 m (4 ft) knee wall height
Number of occupants, age: 2 adults (32 years + 27 years), children planned
Space requirement on ground floor and upper floor: approx. 130 sqm (1400 sq ft)
Office: family use and home office
Guest sleeping per year: rare
Open or closed layout: closed
Traditional or modern design: mixed
Open kitchen, kitchen island: semi-open to dining room
Number of dining seats: 6
Fireplace: no
Heating: bio-district heating, no own heat generator in the house
Music / stereo wall: yes
Balcony, roof terrace: terraces to southeast and southwest
Garage, carport: 2 carports, 2 parking spaces in front of carport
Utility garden, greenhouse: yes
Other wishes / special features / daily routine: controlled residential ventilation, monolithic wall made of brick or aerated concrete. Due to the lack of a basement, the office and utility room must be located on the ground floor.
Owner’s work: flooring, painting, and installation of controlled residential ventilation
Who designed it: by us
What do you particularly like?
What do you dislike?
- We don’t find the entrance behind the carport ideal. However, with the rather small plot, there is hardly any alternative. An entrance facing south is not very good, as we want to use the south side for other rooms. If we put the carport completely behind or next to the house, the house moves too much towards the center of the plot, leaving hardly any meaningful garden space in any direction. Suggestions are very welcome here.
- When entering the bathroom, the first thing you see is the shower wall.
Price estimate according to architect/planner: depending on provider, 190,000 to 250,000, including special features, excluding ancillary building costs and materials for owner’s work
Personal budget limit for the house, including fittings: 210,000, including special features, excluding ancillary building costs and materials for owner’s work
Preferred heating technology: district heating available and mandatory
If you had to give up something, which details or extensions?
- Can you do without: actually nothing unnecessary planned
- Cannot do without: n/a
The exterior dimensions (10.24 m x 9.24 m / 33 ft 7 in x 30 ft 4 in) come from a Flair 134 – this provider has so far been by far the most affordable. The dimensions also fit our plot very well. After many other floor plans with different dimensions, we ultimately chose this one.
Basically, we are very satisfied with it; everything seems to be exactly the size we need. Nothing is too big, nothing too small. Of course, bigger would always be nicer.
Our only points of criticism are:
- the shower wall right in front when entering the bathroom
- the house entrance behind the carport. As a passage between the cars, about 1.40 m (4.6 ft) clearance is planned. Beyond that, there is a passage between the house wall and the shed, about 1.70 m (5.6 ft) wide.
What is your opinion on the overall floor plan and these two points of criticism?
Grundriss: Offener Wohnbereich mit Sofa, Esstisch, Küche, Bad, Schlafzimmer und Arbeitszimmer.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlafzimmer, Bad, Garten und zwei Parkplätze.
Grundriss einer Wohnung mit drei Schlafzimmern, Badezimmer und Flur.
Großes rechteckiges Zimmer mit Holzboden, zwei Türen, zentrale Treppe; Fläche 56,95 m².
Zwei Autos unter einem Holz-Carport vor gelbem Haus auf gepflasterter Einfahrt; braun und blau.
Durchgang zwischen zwei Autos (links lila, rechts orange) unter Gelbstruktur; Wiese dahinter.
Isometrische 3D-Darstellung eines gelben Wohnhauses mit Carport, Garten und Zaun
Aufgeschnittenes Hausmodell von oben; Innenraum mit Küche, Bad und Wohnzimmer sichtbar.
Ansicht eines gelben zweistöckigen Hauses mit Carport, Garten und sichtbarem Obergeschoss.
Arealansicht eines Einfamilienhauses mit gelber Fassade, Carport mit Auto, grünem Garten und Zaun.
stefanc84
5 Mar 2017 12:41
[emoji1]
Oh man, you’re right as usual. On the ground floor, it’s easy to clean from the outside, but less so upstairs. The sashes are quite narrow, so it might still be manageable – but no, both should really be able to open.
If one sash is tilted open and the other isn’t, cats might try to squeeze through the gap to get outside. They inevitably get stuck and can suffocate. Anyone who understands the problem will recognize the "brilliance" of my idea to only tilt one sash open [emoji1] Sorry, I was pretty tired already [emoji51]
Aotearoa
5 Mar 2017 12:48
Stefan, there is still a gap there anyway :ka:
haydee
5 Mar 2017 13:09
Both tilt windows or windows with tilt-locks and cat flaps remain unaffected.
stefanc84
5 Mar 2017 13:10
Aotearoa schrieb:
Stefan, there is still a gap there after all :ka:
That wasn’t meant as a “brilliant idea” anyway [emoji6]
5 Mar 2017 13:22
Nordlys schrieb:
I don’t understand the issue with cats either. We belong to a cat, and she has no problems at all with our windows, some of which are double casement windows. At least, that’s what I believe. She doesn’t meow much; you have to read everything from her eyes, ears, and tail. Karsten
A simple tilt-only position is enough, where the cats can hang out... you can then use a fly screen for the open window. Tilt positions are generally not allowed for cat owners anyway.
Maria16
5 Mar 2017 14:19
Are you planning a light well in the basement for the office? As far as I know, living rooms require a second means of escape, so in the basement, in addition to the internal stairs, there must be an emergency exit such as a sloped escape route (I can’t think of another solution besides an external basement staircase at the moment).
Please transfer the position and size of the basement windows to the ground floor plan; I believe the one in the utility room is located under the entrance and would not work if a stair landing is planned in front of the main door.
