ᐅ Floor Plan Design for a 150 sqm Townhouse with Gable Roof, 6 Rooms
Created on: 28 May 2024 22:14
LeFy2023
Dear forum members,
We have completed a preliminary design for our house together with a company and are now at the beginning of the detailed planning stage. Therefore, we would greatly appreciate any suggestions for improvement, critical feedback, and additional ideas or tips regarding the floor plan.
Unfortunately, we do not yet have a site plan, but we do have the floor plans for the ground floor and upper floor at a scale of 1:100, as well as drawings of the house.
Thanks in advance!
Plot size: 700 sqm (7,534 sq ft)
Development according to §34 of the Building Code; the neighborhood features a wide variety of house types, sizes, number of floors, roof styles, etc. A positive preliminary building inquiry exists for a two-story townhouse up to 200 sqm (2,153 sq ft).
Style, roof type, building type: shallow pitched gable roof, townhouse
Basement, floors: no basement, 2 floors
Number of occupants, age: 2 adults, 1 child (1 year old), possibly a second child planned
Space requirements for ground floor and upper floor: 150 sqm (1,615 sq ft)
Office: family use or home office? Home office for both adults about 3 days per week on average
Occasional overnight guests per year: parents-in-law visit several times a year
Open kitchen, kitchen island: open kitchen with island if possible
Number of dining seats: 4–8
Fireplace: no
Music/sound wall: no
Garage, carport: yes, one parking space including a shed
Utility garden, greenhouse: possibly
Additional wishes / special features / daily routine, also reasons why something should or should not be included:
- Larger guest room on the ground floor with space for a double bed as the parents-in-law visit frequently
- Guest room on ground floor must also be usable as an office
- Bright rooms / mezzanine
- Open entrance area with open rooms and a view of the garden (a clear sightline)
- Straight concrete staircase to upper floor for dogs and parking space underneath (built-in cupboards)
- Office on upper floor should also serve as a utility/laundry room
- Façade in stone gray with wood cladding elements
Designer: planner from a construction company
What is liked most? Why?
- Very practical room layout and good room sizes
- Barrier-free access to the guest shower on the ground floor
- Additional storage space in the roof as a storage binder
- Lots of light through large windows
- Laundry room on upper floor close to the bedrooms/children’s rooms
What is disliked? Why?
- Kitchen might be too small / cramped
- Question whether a passage to the kitchen is necessary
- Main entrance is not barrier-free (terrace exit also not)
- The gray elements in the façade are to be replaced by wood cladding to give the house a more distinctive exterior appearance.
If you had to do without, which details/features?
- Can do without: second washbasin in upper floor bathroom, round window in dressing room (can have a different shape), kitchen island if it doesn’t fit
- Cannot do without: straight concrete staircase, windows, large lift-and-slide door, larger guest room, mezzanine, guest shower on ground floor, walk-in showers, laundry room on upper floor
Why does the design look as it does now? For example,
This is the initial individual draft without adjustments from us so far. A mezzanine, a larger guest room on the ground floor, storage space in the roof, and laundry room on the upper floor were explicitly requested and implemented accordingly.
Thanks in advance!
Fireplace: no
motorradsilke schrieb:
There is also storage space on the washbasin.So, where should the toothbrushes go? motorradsilke schrieb:
which can also be nicely accommodated in the mirrored cabinet.... if not even a mirrored cabinet fits in terms of depth? In this particular furnishing case by the original poster (OP), there simply isn’t enough space planned. A mirrored cabinet protrudes forward; the doors open forward… so it may well be that you can’t even lean forward without leaving a smudge on the mirror. As you can see, there isn’t much room here. The mirrored cabinet would also have to be positioned higher because of the faucet. This, in turn, means that shorter people can’t see themselves properly. Stepping back isn’t possible either because of the bathtub. You’re basically stuck at the washbasin and fiddling with the mirrored cabinet. The towel rack would be the bathtub, and that’s something you could live with...
The point was just to show that it’s not absolutely necessary.A house or a utility room is not absolutely necessary either. Yes, you can, of course, move the utility room wall, but people need to be made aware that this layout really isn’t ideal. I once had a bathroom of just under 6 square meters (about 65 square feet), with a width of around 2.20 meters (7 feet), and there was more space and comfort there.M
motorradsilke16 Jun 2024 15:01ypg schrieb:
So, where are the toothbrushes supposed to go?
... if even a medicine cabinet doesn’t fit in terms of depth? In the original poster’s furniture plan, this space simply hasn’t been considered. A medicine cabinet protrudes forward, and the doors open outwards... so you might not even be able to lean forward without leaving a smear on the mirror. As you can see, there isn’t that much space available.
The medicine cabinet would also need to be mounted higher because of the faucet. This means shorter people wouldn’t be able to see themselves at all. Stepping back isn’t possible either because of the bathtub. You’re stuck at the washbasin and fidgeting with the medicine cabinet. The towel rack would have to be the bathtub, which could be tolerated...
You don’t even necessarily need a house or a utility room. Yes, the utility room wall can be moved, but the point is to be aware that this layout really isn’t ideal. I once had a bathroom that was just under 6 square meters, about 2.20 meters (7.2 feet) wide, and it had more space and comfort.I agree with you that the bathroom layouts you showed look more practical. But it’s not our house — it’s the OP’s house, and it has to suit their taste.
The toothbrushes will be placed on the countertop; it’s wider than the sink, so there’s plenty of room for that.
And a medicine cabinet fits comfortably above it. They aren’t that deep.
We have it that way, and it works perfectly.
The countertop height is about 90 cm (35 inches), and the bottom edge of the medicine cabinet is about 120 cm (47 inches). The grandchildren can easily see themselves in it, which is sufficient for shorter people (hardly anyone is under 140 cm (55 inches), and they usually need other aids anyway).
There’s even room for a pull-out faucet in between, so you can wash your hair.
You never have to stand too close to the medicine cabinet.
kbt09 schrieb:
Regarding the facades
... I’m not sure if those connecting elements between the windows are necessary. Is that supposed to be just a paint detail or some special material?Thank you for your comments on the facades. We have taken your advice into account.
The connecting elements are intended to be wooden facade components. However, I still don’t find the look on the east side very appealing.
I agree that the bathroom layouts you showed are more practical. But it’s not our house, it belongs to the original poster, and they need to like it.The sense of space and room requirements are not matters of personal taste. This is more about a lack of spatial imagination. The guest bathroom unnecessarily feels like standing inside a closet. I recommend mocking up the dimensions with cardboard and furniture to reassess the situation.What do you think about the idea for the bathroom upstairs? The shower wall is marked as 1.5 m (5 feet) there. It’s probably not ideal near the door, but we would like to have an open shower without a door. The bathtub is located there in the
Also, we reconsidered the guest toilet because your comments regarding the layout and, consequently, the size are quite valid. Would it generally be possible to have the entrance to the office under the stairs (with the staircase turned back)? Would this work height-wise? That way, the guest toilet could be moved forward to create more space.
