ᐅ Is it possible to have windows in a guest bathroom or guest room adjacent to a garage?
Created on: 27 Apr 2021 15:24
BauFamily
Is there a way to install a window high up on the wall (like a light strip) in a room or guest toilet that is adjacent to the garage? Since we are planning a basement, the house and therefore this room would be higher than the garage, so a narrow window should be possible, right? Placing windows on the top or bottom walls is not an option due to other adjoining rooms.
What am I overlooking, or why are all rooms adjacent to garages usually shown without windows in floor plans?
Has anyone done something similar before?
nordanney28 Apr 2021 11:56X_SH5_X schrieb:
If the house is built, for example, on a slight slope, you can exit at the back directly onto the garden at ground level. Yes, of course. A hilly terrain is a different matter. My statement refers to a flat, typical plot of land.
nordanney schrieb:
Also, level access to the house and garden is not possible. It is possible. My entrance is level, and then you step into a 2m² (22 sq ft) hallway / stair landing.
BauFamily schrieb:
If the window hadn’t worked out, the entire floor plan would have been useless. Of course the window will definitely work. But is that really desirable? Depending on the direction of rain, water from the garage roof splashes directly onto the glass, so it’s always dirty. Cleaning the window at that height is quite difficult. You could just keep a stool in the guest bathroom. If the window can’t even be opened, you would always have to climb onto the garage first.
How can the entire floor plan depend on the guest bathroom window? It’s one of the least important rooms. People only stay there briefly. There’s no need for an exterior window. I don’t have one either and it doesn’t bother me. You can’t really see outside properly through that window anyway.
BauFamily28 Apr 2021 12:25Tassimat schrieb:
It’s doable. My entrance is at ground level, and then you step into a 2m² (22 sq ft) hallway / stair landing.
Of course, having a window there is definitely possible. But do you really want that? Depending on the amount of rain, water from the garage roof splashes directly onto the glass, so it’s always dirty. Very inconvenient to clean the window at that height. You might as well store a stool in the guest bathroom. If the window can’t even be opened, you’d always have to climb onto the garage first.
How can the entire floor plan depend on the guest bathroom window? That’s one of the least important rooms anyway. You only spend a short time there. You don’t really need an exterior window. I don’t have one, and it doesn’t bother me. You can’t really look outside properly through that window anyway.I should have expressed myself more clearly: where the wall adjoins the garage wall, a guest shower bathroom or a guest room is planned. To provide that room or guest shower bathroom with a regular window, the house needs to be shifted forward. However, this would push the limits of the building area allowance or require a smaller garage.
Putting that aside, I’m wondering whether to build a raised basement or a cellar below ground level. According to the development plan, we could build a raised basement. In the past, houses were mostly built with raised basements, right? Or is that less common today because basements can be better waterproofed? Apart from that, I actually don’t mind a few steps up and a few steps down on the garden side; it might even be positive because dirt tends to stay outside at ground level: leaves, dust, etc. won’t be swept inside despite having flush sliding patio doors. From an aesthetic perspective, a house with a pitched roof and a raised basement looks quite acceptable as well.
BauFamily schrieb:
To put it differently, what speaks against it? In the forum, it’s almost like being stoned if you imply without tact that having a visible basement is not something to be ashamed of;
and in many development plans, a reasonable alignment of the eaves height with the level of the ground floor’s base is often linked to the rule that it should not be more than half a meter (20 inches) above the street level. This, combined with a maximum eaves height of about four and a half meters (15 feet), at least influences many today’s enthusiasts of knee walls to place the basement, if it exists at all, somewhat deeper.
Many future homeowners already feel like “too bad you can’t hit the old man” when I question the sacred garage intermediate door. Your vintage raised ground floor really is quite brave ;-)
BauFamily28 Apr 2021 15:3411ant schrieb:
In this forum, you almost get criticized harshly for simply suggesting that having a visible basement isn’t something to be ashamed of; and in many development plans, a reasonable reference between the eaves height and the level of the ground floor finish is often linked to the requirement that it should not be more than half a meter (about 1.5 feet) above the street. This, combined with a maximum eaves height of four and a half meters (about 14.75 feet), at least encourages those who prefer higher knee walls to dig the basement deeper if it exists at all. Many homeowners already feel like saying "too bad you can't hit the old man" when I question the sacred intermediate garage door. Your vintage raised ground floor design is really bold ;-)Okay, and once again in plain English for those who didn’t get it? 😱 🙄
