ᐅ Floor Plan Evaluation Single-Family Home 147 m² Gable Roof with Extension
Created on: 7 Jul 2022 15:30
KED1234
I have been quietly following along for a while. Since our project is starting to take shape, I wanted to tap into the collective wisdom here and ask for feedback on our early design. Many details are not finalized yet, but the basic structure is becoming clear. Thanks!
Plot size: 381 m2 (4100 sq ft)
Slope: No
Site occupancy ratio: 0.4
Floor area ratio: 0.6
Building envelope, building line and boundary: The current design fully uses the building envelope (except for the terrace area) at approx. 13 x 14 m (43 x 46 ft)
Setback: max. 9 m (30 ft) per side (carport/tool shed fills this), 15 m (49 ft) total
Number of parking spaces: 1
Number of stories: 2 (according to development plan)
Roof type: Gable roof with 45-50° pitch (design currently planned at 50°)
Architectural style: ?? It would be nice if it looks at least architecturally appealing
Orientation: Terrace faces west
Maximum heights / limits: Max eaves height 3.8 m (12 ft 6 in)
Other requirements: - Red/brown brick is mandatory on the main building; 2 m (6.5 ft) minimum distance of roof structures from gable edge required
Owners’ Requirements
Architectural style: Somewhat modern / appealing
Roof type: Gable roof – no flexibility here
Building type: Single-family house
Basement: No
Number of floors: 2 (formally 1.5?)
Number of occupants, ages: 2 adults, 1 child + 1 planned
Space requirements ground floor / upper floor: Standard room needs – 2 children’s bedrooms + master bedroom + office
Office: Family use or home office?: Office mandatory due to significant home office use (1 person)
Overnight guests per year: Few (should be accommodated in the office)
Open or closed floor plan: Basically open but with certain limits (I don’t want to see the kitchen from the sofa, hearing and smelling it is okay)
Conservative or modern construction: Leaning towards modern
Open kitchen, kitchen island: Both
Number of dining seats: 6-8
Fireplace: Would be nice but removed due to budget
Music / stereo wall: No
Balcony / roof terrace: No
Garage / carport: Carport – possibly upgradable to garage (currently drawn as enclosed and without partition to tool shed; this will likely be changed)
Vegetable garden / greenhouse: Vegetable garden would be great but not relevant here due to space constraints
Other wishes / special features / daily routine, also reasons for certain choices:
  • We would like to realize an L-shaped layout to create a sheltered garden and find it visually appealing.
  • The staircase should be open – depending on costs, as an attractive floating staircase (both of us come from homes with open stairs and find noise and odors acceptable).
Planner:
-Architect
  • Long and narrow design. As a result, the house is clearly lower than the neighbors.
  • Floor-to-ceiling windows
  • Generally, I like the room layout
What do you dislike? Why?
  • Unequal size children’s bedrooms (not ideal but acceptable), and one is borderline small.
  • Master bedroom could be slightly smaller. Overall, we haven’t found a better arrangement.
  • I don’t like the small utility room next to the pantry as it is. I would lower it and merge it with the utility room. The pantry would then be a bit higher and mirrored so the door can stay the same.
  • Window sizes and distribution are not final. The office should get a larger glass door for garden access; the living room possibly a large window instead of two smaller ones. I would like wider dormer windows.
  • I don’t like the street-facing elevation yet. It needs lighting near the entrance and the large blank area bothers me.
  • Guest bathroom still needs natural light, possibly from above.
Price estimate according to architect/planner: Still too early. We have rough numbers that seem to be within budget.
Personal price limit for the house, including equipment:
Preferred heating technology: Ground-source heat pump with deep borehole, possibly a ventilation system with heat recovery. (I still need to research to decide my stance in the discussion)
If you have to give up on something, which details or extras
-Can you give up: Facade design. Currently an expensive clinker brick is planned and the wood cladding isn’t cheap either. Windows could be replaced with fixed glazing.
-Can’t give up: It shouldn’t be smaller.
I’m interested in a basic assessment. Please don’t hold back on pointing out mistakes/problems. It’s still early enough to make changes.
Four elevations of a house with roof, windows and entrance, views southwest, southeast, northeast, northwest
Technical map section with red building structures, blue contours and arrows.
Floor plan of a single-family house: living room, dining, kitchen, office, bathroom, garage.
Aerial view of a residential area with red property boundary and dimensions in meters
Attic floor plan: 2 children’s bedrooms left, master bedroom right, bathroom center, staircase in the middle.
Architectural drawing: house sections with roof structure, interior layout and dimensions.
Cadastral map of a plot with red outline and area 381.6 m²
K a t j a12 Jul 2022 17:50
I would remove the partition wall between the living room and dining room. You can clearly see this in Yvonne’s overhead view in #36. The wall feels like an intrusive element. Without the wall, you immediately gain valuable space at the table and a greater sense of openness for living.
KED1234
12 Jul 2022 17:51
hanse987 schrieb:
What I don’t like about the design is the large number of narrow doors. With a rough opening of 63.5cm (25 inches), how wide can the glass actually be? Probably around 40cm (16 inches). The wall thickness will be about the same size. These contribute very little to lighting the room, which is one of the main purposes. Even with a 1m (39 inch) door, only about 75–80cm (30–31 inches) of glass remains.
Hi, we have several window options to choose from. According to the architect, depending on the model, between 50 and 55 cm (20–22 inches) of actual window area would remain. He is currently working on a design with larger windows as well.
KED1234
12 Jul 2022 17:52
I think this is a very important point! Thanks 🙂 D
I’ve already mentioned this, but with wall thicknesses of about 45... 50 cm (18... 20 inches), you should almost only be able to see the individual sun rays that manage to get inside somewhere.
Yes, that bothers me a lot too. You can hardly place a chest of drawers or even a wardrobe anywhere for a clean look.
I’ve been experimenting a bit. The floor area in square meters roughly matches the original... Furniture is used just for scale, wardrobe 200cm (79 inches), closet 300cm (118 inches), table 200 x 100 cm (79 x 39 inches)… Even though I’m not a fan, I’ve hidden doors behind wardrobes (which everyone seems to want nowadays 😉)
Windows nicely symmetrical 😀
Maybe there’s still some ideas for making use of this – otherwise, I think the architect will now have to patch things together from the existing structure.[ATTACH alt="grundrissbewertung-efh-147m2-satteldach-mit-anbau-584077-1.png"]73199[/ATTACH]
[ATTACH alt="grundrissbewertung-efh-147m2-satteldach-mit-anbau-584077-2.png"]73200[/ATTACH]
[ATTACH alt="grundrissbewertung-efh-147m2-satteldach-mit-anbau-584077-3.png"]73201[/ATTACH]
[ATTACH alt="grundrissbewertung-efh-147m2-satteldach-mit-anbau-584077-4.png"]73203[/ATTACH]
[ATTACH alt="grundrissbewertung-efh-147m2-satteldach-mit-anbau-584077-5.png"]73204[/ATTACH]
Thanks, I’ll take a look. However, the orientation to the street doesn’t seem to meet our preferences at first glance.
KED1234
12 Jul 2022 17:55
K a t j a schrieb:
I would remove the partition wall between the living room and dining room. You can see it clearly in Yvonne’s top view in #36. That wall feels like an awkward obstruction. Without the wall, the space around the table immediately becomes more generous, allowing for more freedom in the living area.
Yes, we are still going back and forth on that. Potentially, instead of a wall, we could use a room divider or a piece of furniture to keep it flexible. But then we would probably need to install columns. At the moment, I prefer the version with the wall. Among other reasons, because I’ve learned here how busy a kitchen can get. The wall helps to separate the living room area a bit more.
K a t j a12 Jul 2022 18:46
I wouldn’t plan that as load-bearing. Would a beam below be sufficient?
Myrna_Loy
12 Jul 2022 19:14
2.50 m (8 feet 2 inches) is not enough space for a dining table.
And I wonder why people bother building a house with room to optimize when the answer is always, “we have this now, and it doesn’t bother us.”
Our open-plan kitchen and living area is almost a meter longer than your plan, and it still feels tight. You constantly bump into furniture. If I were building, I wouldn’t plan a kitchen with an island and dining area to be less than 6.50 m (21 feet 4 inches) long.
