ᐅ Experience with damp back walls on Kallax units in basement rooms?
Created on: 24 Aug 2015 18:37
homer
homer
24 Aug 2015 18:37
Hello everyone, I have a rather specific question: I have a Kallax shelf from IKEA in my basement, which I use for storing various items like tools and boxes. Unfortunately, I have noticed that the back panels of the shelf have become damp in some areas, probably due to the generally high humidity in the basement and possibly some moisture coming through the wall behind it.
My question is: Has anyone experienced damp back panels on a Kallax shelf in basement environments? How did you solve or prevent this issue? Have these moisture damages affected the stability or material of the shelf in the long term? And what practical measures can be taken to keep the back panel dry without having to remove the shelf completely from the basement?
I would appreciate any helpful suggestions or experiences specifically related to this combination of damp basements and Kallax back panels. Thanks in advance!
matthewon
24 Aug 2015 19:04
homer schrieb:
Has anyone experienced damp back panels on Kallax units in basement rooms?
Interesting question. To be honest, I think it’s a fundamental mistake to place a wooden or chipboard piece of furniture in a damp basement and then expect it to last forever.
If the back panels become damp, the problem usually isn’t the furniture itself but the unsuitable storage environment. The moist air expands and penetrates the boards – eventually everything warps or the back panel becomes soggy.
I would actually consider opting for metal shelves or plastic ones instead. You can modify a Kallax unit somehow, but it’s always a hassle.
Let’s be honest, who really makes sure their basement is properly dry and sealed? 😉
roman36
24 Aug 2015 19:23
Damp walls behind the Kallax shelving unit in the basement are normal if the basement is damp.
Solution: Do not place shelves directly against the wall, create a gap, allow ventilation, and protect the back panels against moisture (e.g., with a vapor barrier).
V
van_pe
24 Aug 2015 20:11
matthewon schrieb:
I would actually consider using metal shelves or plastic instead.
That's true, using alternatives like metal shelves makes sense.
Otherwise, make sure there is proper ventilation, maybe a dehumidifier or regular airing out. That helps.
Kallax in a damp basement is really not ideal.
NAU34
25 Aug 2015 08:15
I also gave my Kallax in the basement a new lease on life using some simple "basement tricks" 😄 I just slipped a sturdy PE plastic sheet behind the back panel as a splash guard and raised the shelf on small wooden blocks so air can always circulate underneath.
Of course, this isn’t a full solution, but it works pretty well for my needs.
In addition, regular ventilation and dehumidifiers have become my friends. Sometimes you can at least outsmart the basement moisture monster 😉
Joshbe
25 Aug 2015 10:42
In summary, MDF or particleboard backing panels like those used in Kallax units are not suitable for damp basement environments.
A long-term preventive measure is to maintain a permanent minimum gap between the backing panel and the basement wall to ensure ventilation and prevent mold growth or warping in conditions of high humidity.
Additionally, I recommend installing a moisture-resistant barrier (moisture foil) behind the furniture and using dehumidifiers.
In the long run, basement waterproofing can also be a useful solution, although it is technically complex and costly.
