ᐅ Experience with damp back walls on Kallax units in basement rooms?
Created on: 24 Aug 2015 18:37
homer
Hello everyone, I have a rather specific question: I have a Kallax shelf from IKEA in my basement, which I use for storing various items like tools and boxes. Unfortunately, I have noticed that the back panels of the shelf have become damp in some areas, probably due to the generally high humidity in the basement and possibly some moisture coming through the wall behind it.
My question is: Has anyone experienced damp back panels on a Kallax shelf in basement environments? How did you solve or prevent this issue? Have these moisture damages affected the stability or material of the shelf in the long term? And what practical measures can be taken to keep the back panel dry without having to remove the shelf completely from the basement?
I would appreciate any helpful suggestions or experiences specifically related to this combination of damp basements and Kallax back panels. Thanks in advance!
Z
zartra
26 Aug 2015 09:07
Replace the back panels with water-resistant boards, if possible.
Create a gap from the wall and use dehumidifiers.
Regular ventilation is essential.
Otherwise, mold may develop, and the shelf may warp.
Tause
26 Aug 2015 11:19
joshbe schrieb:
A permanent measure for prevention is to create a lasting minimum gap between the back wall and the cellar wall
I consider this the most important point in the discussion.
I would add that, besides the distance, a preventive treatment of the wall and the rear side with a water-repellent coating can also be helpful.
Additionally, it’s worth considering that not only humidity in the air can be the cause, but also rising damp in the wall. In that case, it would be advisable to conduct a moisture test.
NAU34 schrieb:
I simply attached a sturdy PE sheet as a splash guard behind the back wall
Very pragmatic, I like it.
lis64
26 Aug 2015 13:45
If you want to be on the safe side, use laminate or plastic panels instead of the original Kallax back panel.
These are more resistant to moisture and easier to clean.
Also, maintaining a gap of at least 5 cm (2 inches) from the basement wall is ideal for air circulation.
