We have an apartment in a multi-family building that is currently under construction. Today, I noticed that a wall right next to a door has probably cracked while routing the electrical wiring for the light switch. There is an angled/vertical crack, partly almost 1cm (0.4 inches) wide, running completely through the wall, so that on the side near the door, a wedge-shaped section of the wall about 80cm (31.5 inches) high and 20cm (8 inches) wide is essentially hanging free in the air.
Should I be seriously concerned about this and follow up on it, or is this something that occurs frequently and is routinely fixed? (If so, how?)
As a layperson, I am worried that it might just be covered up and that this wedge could eventually collapse entirely.
Thank you,
Dirk
Thank you,
Dirk
farindk schrieb:
Should I be seriously worried about this I would be......
Go to the site manager and show him the damage. He will know how to fix it 😉
