Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Neubau2022
1 Sep 2022 08:16
motorradsilke schrieb:
It’s not about the columns, it’s about the walls between the columns.
At first glance, it looks wrong because walls are usually not built that way.
If you like it, then that’s fine. If it doesn’t hold up, you have a warranty. But if several properties have been built like this, it should work.
It will definitely hold. The columns are hollow inside, and concrete is poured into them. So they are not only built up on the outside but also filled internally.
1 Sep 2022 10:12
Neubau2022 schrieb:
So that they are not only built on the outside but also on the inside.
I think they are also just “assembled,” right? Like Lego? And then filled.
Nida35a1 Sep 2022 10:19
It is just a masonry plinth and will probably last forever.
The advantage of this masonry is that if a vehicle crashes into it, you don’t have to replace the entire structure, only individual stacks, making repairs easier.
Just a thought.
Neubau2022
1 Sep 2022 10:37
I think they are just "plugged" together, right? Like Lego? And then backfilled.
Yes. Exactly. Two covers are loose for the wiring. I will take a photo of the inside today and send it over.
TmMike_2
1 Sep 2022 13:06
Neubau2022 schrieb:
It’s not a big deal. As I said, in our village all fence walls and pillars look like this. I also checked out five other projects by the same company near Berlin, and they look exactly the same. It might also be due to the region. For example, in the south, Triflex is used for waterproofing, which is never an issue here in Brandenburg. Here are some pictures of their work. I don’t understand why it bothers you so much? If it’s just about appearance, it’s ours. But if it’s about shoddy workmanship, then get rid of it, why not 🙂
In this case, it is basically just a matter of appearance. It also saves on material waste.
1 Sep 2022 13:52
TmMike_2 schrieb:
In this case, it’s really just aesthetics. It simply reduces waste.
There are also so-called half-bricks if you want an offset. At least I found a similar system with tongue and groove online.
