ᐅ Commissioning of the network installation
Created on: 28 Apr 2016 14:10
bergi
I hope the topic description fits my question. Our house is now turnkey ready. The electrician rolled up all the network cables and hung them under the circuit breaker panel in the utility room.
For cost reasons, I would like to connect the cables to the patch panel myself.
I have 6 network outlets in the house. So I need a patch panel with at least 6 ports. A network switch and a Fritz!Box are already available.
Which patch panel would you recommend?
What else do I need to connect to the patch panel?
The "small thin gray" cable is the telephone connection, right? Which connector do I need for that?
I hope you can give me a bit of guidance.
Zusammengewickelte Elektro-Kabelrollen in einer Ecke neben Wand und Bodenbelag, Bauinstallation.
Uwe8229 Apr 2016 11:01
Normally, there is always a color scheme for the A and B variants printed on the back. If the sockets are already installed, ask your electrician which variant they used, otherwise it’s a 50/50 chance.
I always chose A because the wires lie next to each other as they were twisted. If necessary, you can also check this on a socket.
Caspar2020
29 Apr 2016 15:11
I would avoid crimping. Using an LSA tool to terminate on the patch panel, on the other hand, is really straightforward. Especially since it’s also easy to fix if needed.
bergi
1 May 2016 18:07
So, I took another photo of the phone connection today. Is it now prepared well enough that I just need to attach the plug to the cable and then connect it to the Fritz!Box?
White boiler with yellow warning label, pipes at the bottom, wall-mounted.
Sascha aus H1 May 2016 18:34
Unfortunately, I cannot tell from the picture what is wrong with the cable.
You can definitely see the primary line connection box (APL) there. Was a telephone socket installed next to it?
If so, you would need to plug the cable from the Fritzbox into this socket (if the phone runs through it); otherwise, in addition to the telephone socket, a splitter would need to be installed.
Uwe821 May 2016 18:52
There probably won’t be any more Splitter devices due to the digital connection.
Sascha aus H1 May 2016 19:08
That’s why the note on how he is trying to connect something. There are still regions in Germany where old connections are still in use.
