ᐅ Is it possible to replace or repair IKEA Brimnes doors yourself?
Created on: 1 Nov 2020 09:17
Carolinemu
Carolinemu
1 Nov 2020 09:17
Hello everyone, some time ago I bought an IKEA Brimnes sideboard, and now the doors are damaged. My specific question is: Is it possible to replace or maybe even repair IKEA Brimnes doors without having to replace the entire piece of furniture? I would like to know if there are recommended replacement parts available from IKEA, what tools or preparations are needed for a door replacement, and to what extent minor repairs (e.g., scratches, hinges, or misalignments) are feasible. If anyone has practical experience with this, I would appreciate any tips.
Aimee
1 Nov 2020 09:46
Yes, IKEA offers replacement parts for Brimnes doors, and individual doors can also be ordered separately. Be careful when removing the doors: hinges are often secured with clips. For small scratches, sandpaper and wood filler are helpful.
rubybi
1 Nov 2020 12:08
Additional information: If you want to replace Brimnes doors yourself, it is helpful to first note the exact model name, as this makes finding the correct replacement parts much easier. To remove the door, start by unscrewing the hinge screws using a Phillips screwdriver. For minor repairs such as scratches or chipped edges, I recommend:
- Sanding the affected areas with fine-grit sandpaper
- Filling with wood filler or repair wax in a matching color
- Carefully sanding again after drying
- For hinges, you can often adjust the alignment—either manually or by turning the screw to correct misalignments
IKEA offers replacement hinges through their customer service if they are damaged. For a complete door replacement, simply inquire online or at an IKEA store. Screws and assembly instructions are generally the same.
ronti
1 Nov 2020 15:17
Replacing a door is usually straightforward, as most hinges are the same size. Scratches can be repaired with a furniture touch-up marker or repair wax. Only buy a new door if there is significant damage.
GEKAU51
2 Nov 2020 08:31
Let’s be honest: Why make it so complicated? IKEA furniture is simply not designed for long-term durability. I almost find it a waste to repair the doors. Replacing them is usually faster and cheaper than a half-baked DIY fix.
rubybi schrieb:
Anyone wanting to replace Brimnes doors themselves should first note the exact model name, as this makes finding the right spare parts much easier.
That’s true, but IKEA often follows a standard pattern – you can usually manage with common sense and basic tools without having to go through pages of manuals.
In my opinion, repairing is mostly a waste of time here.
Katan
2 Nov 2020 11:42
I think repairing has its own charm – almost like furniture care! Sure, replacing parts is straightforward, but if you enjoy a bit of DIY, you can achieve great results with some patience.
GEKAU51 schrieb:
In my view, repairing is usually a waste of time here.
I partly agree, but sometimes small repairs give the piece a personal touch. Plus, it's better for the environment if you don’t throw everything away immediately. 😉
My tip: Make sure to work carefully when repairing and seal the areas properly to ensure long-lasting results.
