ᐅ Is it possible to replace or repair IKEA Brimnes doors yourself?
Created on: 1 Nov 2020 09:17
Carolinemu
Hello everyone, some time ago I bought an IKEA Brimnes sideboard, and now the doors are damaged. My specific question is: Is it possible to replace or maybe even repair IKEA Brimnes doors without having to replace the entire piece of furniture? I would like to know if there are recommended replacement parts available from IKEA, what tools or preparations are needed for a door replacement, and to what extent minor repairs (e.g., scratches, hinges, or misalignments) are feasible. If anyone has practical experience with this, I would appreciate any tips.
maunau70
2 Nov 2020 15:03
I can confirm that Brimnes doors can be easily replaced. The doors have standard hinges, so no special tools are needed except a screwdriver. If the doors are warped, repairing them often makes little sense. In that case, it’s better to order new ones.
Carolinemu
3 Nov 2020 09:22
Thank you for the responses so far! A few more questions: How does color matching work with replacement parts? I assume there are slight variations in the white finish depending on the year of production? And what about the hinges – do you notice any visual or functional differences when using original parts versus repair or third-party parts? I want to avoid doors that don’t close properly or hang unevenly.
rubybi
3 Nov 2020 13:19
Good questions, Carolinemu. Basically, IKEA tries to offer replacement parts that match the original color as closely as possible. However, with white surfaces, there can be slight differences in shade due to different production batches or aging.
The hinges for Brimnes are standardized. Original parts ensure full compatibility in function and installation. Third-party or used hinges can be a bit loose or difficult to adjust, which can cause misalignment. If the doors don’t close properly, it is often due to bent or worn hinges. Therefore, it is advisable to use original hinges, especially if you are looking for a long-lasting solution.
If you only finely adjust the doors without replacing defective parts, this can often work wonders.
Genuan
4 Nov 2020 07:56
In summary: Brimnes doors can be easily replaced by yourself. Spare parts are available, and the tools required are simple screwdrivers. Minor damages can be repaired, for example by sanding or filling. For edge and hinge issues, original screws and hinges are best. Anyone with time and willingness can manage this without any problems.
