I am currently planning to redesign my basement and was wondering if the popular IKEA PAX wardrobe can also be used in a basement.
It is important to me that the wardrobe remains stable, is not quickly affected by moisture, and that the materials do not suffer, since unfortunately I do not have perfect climate control in my basement.
Has anyone had experience with setting up the PAX wardrobe permanently in a basement? Is there an increased risk of mold or warping of the wood in such a setting?
I look forward to your opinions and advice on what a layperson should consider when using the PAX wardrobe in a basement.
Thank you in advance!
Hello Fadutra,
First of all, your question is very valid, as basement environments differ significantly from regular living spaces, especially regarding temperature and humidity.
Regarding the PAX wardrobe in the basement:
- Material: The PAX wardrobe is mainly made of engineered wood products (particleboard, MDF) with a foil or lacquer finish. These materials are generally not designed for high-humidity environments.
- Moisture risk: Basements often have higher humidity levels, which can cause the wood to swell and warp. This may result in stress cracks, edge swelling, and reduced stability.
- Mold: If humidity levels stay above 60 percent, mold can develop on the wardrobe or within the construction. This is both a health concern and damaging to the material.
Therefore, I recommend the following:
- Measure the basement’s humidity over a longer period before installation.
- Ideal values are below 60 percent, preferably between 40 and 55 percent.
- If levels are higher, dehumidification is advisable, for example with an electric dehumidifier or through building modifications.
- Placing the wardrobe on legs or a slightly raised platform can help keep moisture away from the floor.
In summary: The PAX wardrobe is not specifically designed for basements with high humidity but can function there with the right precautions. I also strongly recommend not placing the wardrobe directly against the wall to allow for air circulation.
I would also be interested to know how your basement is ventilated and whether there are other pieces of furniture present that require similar considerations?
bapar schrieb:
The PAX wardrobe is mainly made of engineered wood products (particleboard, MDF) with a foil or lacquer finish. These materials are generally not designed for environments with high moisture levels. I would like to add:
Although the finishes are water-resistant, prolonged exposure to high humidity and temperature fluctuations can cause small cracks, allowing moisture to penetrate. This can lead to long-term damage to the material.
bapar schrieb:
If the humidity level remains above 60 percent, mold can develop on the wardrobes or within their structures. This is very important. Regular ventilation of the basement and considering an air supply or exhaust system to manage moisture levels can help.
If air conditioning or climate control is not possible, it might be worth considering mold-resistant alternatives or at least ensuring good air circulation inside the wardrobe’s interior components (e.g., drawers and shelves).
In summary: If you can ensure that the humidity in the basement is controlled, there is no problem using the PAX wardrobe there. Otherwise, issues may arise.
