ᐅ Can I use Pax wardrobes for storage in the hallway?
Created on: 5 Feb 2021 19:42
Mu_ren
Mu_ren
5 Feb 2021 19:42
I am considering using one or more IKEA Pax wardrobes as a storage solution in my hallway. Although my hallway is not very large, I urgently need more space for coats, shoes, and various household items that tend to accumulate there.
Can anyone share their experience with using Pax wardrobes for hallway storage? How do the dimensions and customization options work?
I’m especially interested in whether the wardrobes are sturdy enough to handle frequently used outerwear and possibly heavy shoes. Also, how flexible are the interior fittings, and can they be easily adjusted to meet the specific needs of an entryway?
I appreciate any tips and advice, including alternative suggestions if Pax is not ideal.
Takutau
5 Feb 2021 20:18
Pax wardrobes are generally well suited for hallways because they are very versatile. You can adjust both the width and the height and customize the interior—for example, with hanging rails, shelves, shoe compartments, or drawers.
Regarding stability: the construction is sturdy enough for everyday use, but you should make sure to secure the wardrobe properly, especially if you build it tall. For shoes, special inserts are useful to keep the wardrobe from getting dirty quickly.
When it comes to the hallway, consider how much space you have. Pax wardrobes are often quite deep (about 58 cm (23 inches)), which can narrow the passage. In narrow hallways, you might also consider shallower models, but they have limited interior organization.
I recommend measuring carefully first and then making a plan for what you want to store.
pilous
6 Feb 2021 09:37
Takutau schrieb:
Pax wardrobes are generally well-suited for hallways because they are very versatile.
That is true, but I would qualify that these wardrobes are not automatically the best solution for every hallway.
- Hallways are often narrow, and the depth of 58cm (23 inches) is quite bulky, especially in small apartments.
- The space required to open the doors can also quickly become an issue, particularly if the hallway also serves as a passageway.
- The wardrobes are indeed sturdy, but adapting them to a hallway, which often experiences varying dust and moisture levels, is not always ideal.
Therefore, it is important to carefully consider how flexible you need the interior layout to be and whether you might want to look at more modular or hallway-specific systems that are slimmer.
liskar
6 Feb 2021 11:04
From a practical perspective, Pax cabinets can definitely be used as hallway storage if you keep the following points in mind:
- Dimensions: Standard depths are 35 or 58 cm (14 or 23 inches). For hallways with limited space, the 35 cm (14 inches) deep model is better suited, but this reduces storage capacity.
- Stability: The cabinets are designed for residential use and can easily handle typical loads such as coats, shoes, and everyday items. Proper installation and wall mounting are essential.
- Interior fittings: Pax offers various storage options, including hanging rods, drawers, baskets, and shoe racks, which makes customization easier.
- Indoor climate: In case of humidity, it’s important to choose suitable materials and maintenance to prevent mold or damage.
Overall, I recommend planning according to your room measurements and considering the 35 cm (14 inches) version if the hallway is narrow. The customizable interior fittings are an advantage. It’s also worth considering whether to choose doors or sliding doors, the latter saving space when opening.
Jorgela
6 Feb 2021 12:09
Pax wardrobes work well in hallways if there is enough space.
- Doors are a better choice than open shelves to prevent dust.
- A depth of 35cm (14 inches) is ideal for narrow hallways.
- Plan the interior organization simply and use shoe compartments.
Otherwise, compact wardrobe/hallway furniture is often more practical.
