ᐅ Can I modify IKEA Metod kitchen cabinets when I move to a new home?
Created on: 22 Mar 2021 18:07
Bengt57Hello everyone, I am currently considering whether I can take my existing IKEA Metod kitchen with me when I move and then rebuild it. Specifically, I am interested in whether the Metod kitchen cabinets are designed in a way that allows them to be relatively easily disassembled, transported, and then reassembled in a different kitchen, possibly with a different layout or minor modifications. Are there any structural limitations, for example due to the connecting hardware, stability, or modular design, that would prevent this? Or has anyone had experience dismantling a Metod kitchen and then reassembling it, even rearranging or adjusting individual cabinets? I would like to avoid having to buy everything new if possible, but of course, the kitchen should remain stable and durable after the rebuild. Thanks in advance for any tips, experiences, or advice!
Bengt57 schrieb:
Specifically, I’m interested in whether Metod kitchen cabinets are designed so that they can be relatively easily disassembled, transported, and then reassembled in another kitchen, possibly with a different layout or minor adjustments.I completely understand wanting to take as much of your kitchen with you as possible – it definitely saves money and effort. I moved some time ago using Metod cabinets myself. Basically, the units are modular and can be taken apart fairly easily. But be careful: the holes and drillings are fixed, so you’ll need suitable fittings if you want to set up the cabinets in a different (altered) arrangement.
Transport isn’t without risks – I experienced minor damages to edges and connectors because the surfaces aren’t extremely durable. It’s highly recommended to pack all parts very carefully and to label or secure the screws systematically, otherwise you’ll spend a lot of time searching for them later.
Reassembly works well as long as the new layout is compatible with the standard dimensions. If you plan to cut the cabinets extensively or make significant changes, it can lead to stability problems. I was lucky because I only made minor adjustments. Overall, the Metod design felt sturdy enough if handled carefully. Still, it’s not exactly "frequent disassembly friendly," and it requires more effort than some flat-pack furniture, but that’s to be expected.
If you don’t have experience, be aware that rebuilding can take a long time and demands patience. I hope this helps at least a little.
REOHEINRIC23 Mar 2021 08:53Bengt57 schrieb:
I want to avoid having to buy everything new if possible, but of course the kitchen should remain stable and durable after the renovation.From a technical perspective, the following can be noted:
- IKEA Metod is modular and allows for the removal of individual cabinets.
- The geometry and drillings are standardized, but they are designed for the original installation.
- Transport and reassembly are possible, but modifications require realignment of the fixing points.
- The connectors (dowels, cam locks) can be reused, but their durability decreases with each disassembly and reassembly.
- For larger modifications or changed dimensions, it is advisable to have spare parts or additional fasteners on hand.
- Stability is good if all connections are properly installed. When rebuilding, it is recommended to carefully align the cabinets and use additional reinforcements if necessary.
I recommend precise planning with accurate measurements of the new kitchen before starting the renovation. Building conditions (walls, connections) can significantly affect the feasibility.
In summary: Renovating Metod kitchen cabinets during a move is technically possible and often practical, but requires craftsmanship and time. Buying entirely new units is only necessary if the new kitchen layout is significantly different or if visible damage is present.
koduga schrieb:
Transportation is not always without risk – I had minor damage to edges and connectors because the surfaces are not extremely durable.I have to strongly disagree – I find that Metod cabinets are absolutely not designed for reassembly after a move. IKEA sells relatively affordable furniture, which is reflected in the materials and composite boards used. The edges are vulnerable, and anyone who really wants to disassemble and reassemble multiple times is, in my opinion, naive.
Furthermore, when you talk about "reconfiguring"—changing the layout and needing to drill new holes in the frames or cut panels—that usually ends in a patchwork of spare parts, misaligned fronts, and unstable constructions.
My take: IKEA Metod is an affordable mass-produced solution, not a durable system built to last. If someone moves and rearranges frequently, I believe it’s better to invest in professional or modular systems with higher quality.
Bengt57 schrieb:
I want to avoid having to buy everything new if possibleUnfortunately, we no longer live in times when you can just take everything along and modify it without losing quality. Economically, it’s not necessarily sensible either, considering the time involved and potential damage.
