ᐅ Is it easy to modify Ikea Metod kitchen cabinets if the room dimensions change?
Created on: 11 Nov 2019 09:23
lincolnju
lincolnju
11 Nov 2019 09:23
Some time ago, I planned and assembled a kitchen using IKEA Metod kitchen units. Now the room size has unexpectedly changed, which means I need to adjust the existing kitchen units to fit the new space. My specific question is: Can I simply modify or rebuild the IKEA Metod units if the room dimensions change, or are there limitations I should be aware of?
In particular, I’m interested in whether the individual components are flexible enough to accommodate different measurements, if individual cabinets and fronts can be replaced, and how this affects stability and functionality.
I would appreciate any experience, tips, or advice that could help me better assess the situation. Thank you!
SEKAR
11 Nov 2019 09:47
IKEA Metod furniture is basically modular, which makes adjustments easier. You usually cannot change the cabinet width and height continuously, but the combination of different cabinet widths offers flexibility. Front panels are replaceable. It is important to take precise measurements and plan carefully before ordering or modifying any parts.
batabe
11 Nov 2019 10:12
I agree with the statement. Another important point is that certain Metod components have standardized dimensions (usually 20, 40, 60 cm widths). If your space does not exactly match these dimensions, you will need to use filler panels or custom adjustments.
Sometimes it makes sense, for example, to cut a filler panel or a plinth individually to make the best use of the space. This is possible but requires some craftsmanship skills.
You should also keep an eye on the connections and built-in appliances, as not all modules can be moved freely.
sanjon
11 Nov 2019 10:45
When the room size changes, it is often better to completely redraw the planning rather than remodel individual modules. IKEA Metod is modular but not designed for seamless adjustment. Cover panels and filler pieces help with incorrect measurements.
bujufa
11 Nov 2019 12:01
It is also important to know that the stability of the Metod cabinets is ensured by their specific construction. Modifying the furniture by cutting or altering it yourself can compromise this stability. Therefore, I strongly recommend relying on professional cutting for panels or toe kicks when making size adjustments, and keeping the main units in their original condition.
As batabe already mentioned, anyone familiar with the principle of standardized widths can compensate a lot through careful planning, without having to cut or change the basic structure of the cabinets.
lincolnju
11 Nov 2019 13:15
SEKAR schrieb:
Basically, IKEA Metod furniture is modular, which makes adjustments easier.
Thanks for the tip. If I want to keep the existing cabinets—like base cabinets about 60cm (24 inches) wide—and replace them with narrower ones, for example 40cm (16 inches), is that straightforward? Or do I need to redesign the entire kitchen run?
batabe schrieb:
Sometimes it makes sense to custom-cut a panel or a kickboard to best fill the available space.
Can you say something about stability if I cut or adjust panels myself? Are there any limitations with this approach?
