Created on: 27 May 2019 10:48
goalkeeper
goalkeeper
16 May 2022 14:36
apokolok schrieb:
That's true, these things cause lots of broken bones, torn ligaments, knocked-out teeth, and so on.
By the way, I prefer option 2. It makes better use of the garden, and you want to keep a sandbox as far away from the patio as possible; otherwise, you’ll end up with a sandy patio. I don’t see any downside to having the gate in the middle. Maybe I would also pave a narrow path to the gate with patio slabs. The gate should be wide enough to easily get a wheelbarrow through.
I mostly agree with you. However, the fence there is only 1.40m (4 ft 7 in) high—so uninterrupted splashing would be difficult. In option 1, the sandbox and later a small pool would be placed in front of the 1.80m (5 ft 11 in) high WPC privacy screen.
Also, the problem with option 2 is that the neighbor across the street can always look through the gate into our living room. With option 1, you can plant continuously so you still have a natural privacy screen.
The gate will definitely have a clear width of 1.00m (3 ft 3 in).
TmMike_2
16 May 2022 15:14
apokolok schrieb:
Make better use of the garden, and you ideally want the sandbox as far away from the patio as possible; otherwise, you’ll quickly end up with a sandy patio. I don’t see any disadvantage to having the gate in the middle. Maybe I would also pave or cover a narrow path to the gate with patio slabs. The gate should be wide enough to easily get a wheelbarrow through.
regularly adding sand can actually help keep the lawn nice and green 😉
kbt09
16 May 2022 16:45
I wouldn’t plan anything with additional pathways or similar at Goalkeeper. The garden is really not very big, and having a bit of continuous lawn area ... keep in mind it’s only 24 sqm (260 sq ft)!! ... should definitely be a priority.
apokolok
16 May 2022 20:43
Well, if you’re talking about a pool, I would assume the most likely option would be an inflatable hot tub.
If it ever comes at all, you could easily place it on the terrace.
The location of the terrace door would be interesting to know; I don’t have that information on hand right now.
In general, the layout isn’t set in stone—you can redesign a garden like this, especially if it is relatively small, every few years.
I understand the issue with a door in the fence; if the neighbor is troublesome, that’s definitely a problem.
What about playgrounds or outdoor public pools nearby? I have always preferred those over having something in my own garden, except for a larger paddling pool. But even that was just something I could deflate after a few days. I never wanted to deal with the maintenance, filters, and so on. A season pass is definitely more affordable than anything serious when it comes to a pool.
goalkeeper
17 May 2022 08:51
apokolok schrieb:
Well, if you’re talking about a pool, I would assume at most some sort of inflatable hot tub.
If it ever comes to that, you could just put it on the terrace.
The position of the patio door would be interesting to know; I can’t recall it right now.
In any case, the layout isn’t set in stone—you can always redesign a garden, especially a smaller one, every few years.
I understand the issue with a door in the fence; if the neighbor is annoying, that’s not ideal.
What about nearby playgrounds or outdoor swimming pools? I’ve always preferred those to having something in the garden, only had a larger paddling pool myself. But just one that I could drain after a few days—I never wanted to deal with filtration systems and so on. A seasonal ticket is definitely cheaper than anything serious when it comes to pools.
You’re completely right. Right now, the garden is mainly designed for the kids. Various toys will, of course, still be added.
There is a playground nearby since it’s a new development. However, as a parent, it’s much more convenient sometimes to just sit comfortably on the terrace, have a coffee, and watch the kids play or splash around in the garden.
Every time you have to pack all the gear like changing supplies, tons of snacks for the little ones, swim shoes, catch the kids, get them in the car, drive to the pool, pay entrance fees, and so on, it can be more complicated than just putting the kids into a small pool in the garden.
Unfortunately, over the past few years, we’ve been forced to “escape” to pools or playgrounds since we didn’t have a child-friendly garden. We wanted to catch up on that now. Whether there will actually be a pool with a filter system later on remains to be seen for now.
goalkeeper
24 May 2022 09:31
When the landscape contractor has blocked their own access.
Construction site: Crane lifting a load at the white house; mini excavator, cables, and construction equipment in the yard.
