Created on: 27 May 2019 10:48
goalkeeper
Vicky Pedia27 Mar 2020 12:52
Altai schrieb:
I think around €350 for the outlet where the dimmer would be installed makes sense, assuming the spots are dimmable in principle... but they would still be cool white...
I don’t know the exact situation, but I think that cost is clearly too high!! It was just a suggestion! And why an outlet? The dimmer replaces the light switch, unless you have a double switch for the mentioned mirror.
Vicky Pedia27 Mar 2020 12:55
danixf schrieb:
The dimensions are usually standardized. There are also larger ones with low intensity. The question is just how it is wired... But basically, you just need to buy the appropriate light bulbs and replace them.
Since we don’t know the product, it seems to be LEDs. In that case, you cannot replace the "light bulb."
Climbee27 Mar 2020 13:20
And LEDs are not always dimmable. In that case, even a dimmable switch may not necessarily help.
Altai
27 Mar 2020 13:35
I’m not sure if the spotlights are dimmable.
Vicky Pedia schrieb:
I don’t know the exact situation, but I think the costs are way too high!! It was just a suggestion! And why an outlet? The dimmer replaces the light switch, unless you have a double switch for the mentioned mirror.
In my living room, there was a double switch, so the outlet had to be removed because the dimmer takes up a full “slot.” In the bathroom, there is also a double switch (the other one for the mirror), so…
Regarding the costs, my bad, in fact TWO dimmers cost €350 (280 + VAT, and that was just the material), so sorry, €175 each then… that is the amount shown on the electrician’s invoice, who replaced the double switch and the outlet with two dimmers in the living room. Plus labor costs.
RomeoZwo28 Mar 2020 13:53
We don’t know the product, but it seems to be LEDs. In that case, you can’t replace the “bulb.”
You can’t generalize like that. Our spotlights all have a GU10 socket and are equipped with LED bulbs. This has the advantage that if something breaks, you can replace the bulb.
Yes, LEDs fail much less often than incandescent or halogen bulbs, but it can happen—usually not the LED itself, but the small circuit board that converts 230/24/12 V to about 3 V for the LED.
If the spotlights are being prepared in a concrete ceiling anyway, it’s definitely advantageous to use those with replaceable bulbs. If retrofitting, fixtures with fixed LEDs are easier, as they are significantly slimmer to install.
Vicky Pedia28 Mar 2020 14:37
As I said, we are not familiar with the product and do not know whether it is a concrete ceiling. In the bathroom, there are many indications it is the upper floor. But it’s all speculation. Only @Altai can say for sure.
