ᐅ Billy shelf unit – How to prevent the doors from drifting out of alignment – Tips and tricks.
Created on: 13 Oct 2021 19:37
PLOFA
Hello everyone, I bought a Billy shelf unit and I’m facing the problem that the doors keep shifting on their own. Because of this, they no longer align properly and it looks untidy. I know that you can adjust the screws and hinges, but are there any specific tips or proven methods to stop the doors from shifting permanently? I’m not referring to the usual trial-and-error adjustments by eye, but rather practical solutions to ensure long-term stability and avoid the need for readjustments. Thanks in advance for any advice!
RON57
14 Oct 2021 14:10
I would like to add that slight inaccuracies during the assembly of Billy shelves can sometimes cause misalignments. By working very carefully, using a spirit level and precise measurements, many problems can be avoided. Additionally, it can help to slightly pre-adjust the doors—that is, set them so they don’t close perfectly flush—to prevent pressure that might loosen the screws.
If readjustment is needed after a few weeks, I would not consider this a technical defect but rather a result of the materials and normal use. A Billy shelf is not a professional-grade piece of furniture but designed for home use. Tips like using felt pads and thread-locking adhesive are therefore very useful to reduce maintenance effort.
koduga
15 Oct 2021 10:05
I am very familiar with this issue and understand how frustrating it can be when doors keep moving out of alignment. It is especially annoying when the cabinet is in a living room with high humidity, as the doors seem to change position constantly.
What really helped me was realizing that the misalignment is not just a technical problem but also related to how the doors are used. For example, I now make sure to open and close the doors gently and avoid slamming them shut.
Additionally, I have used small transparent rubber bumpers on the edges to prevent the doors from banging directly against each other. These help reduce wear and tear and promote smoother operation, which in turn minimizes misalignment.
Lastly, I think magnetic catches are a great idea, but they do require some basic DIY skills to install them accurately.
