Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
tumaa
8 Apr 2020 08:49
Climbee schrieb:
When the sauna is heating up and I slip a roast into the stove pipe at the same time
sorry ... but I have to laugh out loud
rick20188 Apr 2020 09:17
@Climbee We have a 9.8 kWh battery storage from LG.
We purchased a complete package, so the individual price cannot be specified exactly.
Depending on the inverter, not every battery is compatible.
Through this deal, we also got a higher quality inverter.
If I had to estimate, I would guess the battery storage cost around €6,000.
research86
8 Apr 2020 09:19
Even though I find the way you are implementing this really beautiful project and that you have done your research incredibly impressive, you are unfortunately mistaken or have been misadvised regarding your photovoltaic system...
rick2018 schrieb:
No, there will be no additional modules. The system has a capacity of 9.920 kWp.
Even though it’s not economically profitable, we have a system with a battery storage. The offer was very good...
Once you exceed 10 kWp, it only makes sense if you significantly surpass that. Since setbacks to the parapet and so on must be observed, we could not add many more modules than the current ones.
We will operate the system with dynamic active power limitation. Since we always have a high base load, the system can run at 100%. This way, there is at least no strict 70% cap because self-consumption is taken into account.
We could definitely use more photovoltaic power.
Our other roof sections are too small, partly shaded, greened, used otherwise, etc.
You have a roof that could accommodate at least 15-20 kWp with sufficient side clearance. Your modules are probably mounted on frames facing east/west. This usually helps to achieve a high self-consumption throughout the day (even without storage). With your system, you will never reach significantly more than 70% of your modules’ peak capacity. In fact, a strict 70% cap could even be considered here.
If you want storage, all modules should face south for maximum yield. Otherwise, without storage, east/west and the often-cited “roof fully utilized” approach is best.
Even if it probably doesn’t bother you too much if the photovoltaic system is not ideally matched or profitable, more could have been gained here.
rick20188 Apr 2020 09:23
The storage is just a gimmick. I understand that. How much we can load it will remain to be seen.
Taking the spacing into account, a maximum of 15 kW could have fit. We didn’t want the additional effort regarding the investment and taxation.
But thanks for the valuable input.
tumaa
8 Apr 2020 09:52
research86 schrieb:
Even though I find the way you are implementing this beautifully designed project and your thorough research incredibly impressive, unfortunately, you’ve missed the mark or have been misadvised regarding your photovoltaic system...
You have a roof that can easily fit at least 15-20 kWp with plenty of side clearance. Your panels are likely mounted on racks facing east/west. This setup usually helps achieve a high self-consumption rate (even without a battery) throughout the day. With your system, you will never significantly exceed 70% of your modules’ peak capacity. In fact, reaching over 70% would be quite optimistic.
If you want a battery, then all panels should ideally face south for maximum yield. Otherwise, without a battery, east/west orientation and the often-cited “full roof” approach is best.
Even if it might not bother you much if the photovoltaic system isn’t optimized or profitable, you could have gotten more out of it here.
Honestly... if I had the money, I wouldn’t care at all.
Rick is very down-to-earth, a good guy... I like it!
research86
8 Apr 2020 09:57
Exactly for this reason my response, because with his vast acquired knowledge he has helped not only me (indirectly) but also others.
