ᐅ Are there ways to assemble IKEA PLATSA furniture without using screws?
Created on: 31 Jul 2020 08:23
NEILIR
NEILIR
31 Jul 2020 08:23
Hello everyone, I have a question that might sound unusual: Is there any way to assemble IKEA Platsa furniture without the usual screws?
I am currently considering whether the PLATSA series can somehow be assembled tool-free or at least screw-free, for example using snap-fit joints, specialized connectors, or alternative assembly methods. The main goal would be to find a faster way to build it, as I find the typical screw connections somewhat inconvenient, especially if you frequently rearrange or disassemble the furniture.
Has anyone here had experience or even their own solutions or tricks for connecting the furniture from the PLATSA range with as few screws as possible? I look forward to your suggestions and ideas, especially practical advice on how stable the result remains.
Samuel
31 Jul 2020 09:18
NEILIR schrieb:
Are there any ways to assemble IKEA PLATSA furniture without the usual screws?
Hey Neilir! Good question, you’ve definitely picked a challenge 😄.
In short: IKEA designed the PLATSA system primarily for screw joints and dowels because that ensures stability. But I’ve heard that some people use so-called assembly clips when moving – small clips that you slide in between parts to hold them together without screwing.
Whether that works for the entire piece of furniture is questionable. The advantage: quick assembly and almost no tools needed. The downside: not very sturdy. Maybe okay for shelves that won’t carry much weight.
Perhaps this could be considered as a temporary solution?
BEMAU
31 Jul 2020 11:42
Regarding the question of whether IKEA PLATSA furniture can be assembled without screws: The design of the PLATSA series primarily relies on screw connections, dowels, and precisely fitting fasteners.
- Alternative fastening methods, such as wooden joints without screws, are not intended for these modules.
- Mounting clips or universal connectors cannot provide the same stability as a screwed system.
- The absence of screws can limit the overall load capacity and durability, especially for shelves or cabinets.
Conclusion: Technically, it is only possible with compromises in stability and durability. For long-term use, the screw mechanism is clearly preferable.
LOJOPAR
1 Aug 2020 07:37
Samuel schrieb:
some people use so-called assembly clips during moving – small clips that are inserted to hold the parts together without screwing.
That’s true, small assembly aids can be helpful temporarily, but I would recommend a step-by-step guide if someone wants to try this:
- Align the parts precisely and check for any stresses or tensions.
- Use clamps or clips strategically to prevent warping.
- Apply additional clamping devices if available (e.g., clamping strips).
Important: These solutions are generally intended for temporary use or trial fittings, not for the final assembly. I also advise using the original screws for PLATSA, as otherwise the warranty may be voided and the load-bearing specifications might no longer be accurate.
PLOMA
1 Aug 2020 15:04
Interesting idea with the screwless assembly. When it comes to IKEA PLATSA modules, they are designed by default for fastening at multiple points to handle lateral forces and weight. Avoiding screws requires different connection methods, which can only be implemented with extensive craftsmanship adaptations:
- Wooden plug joints are possible but often problematic with particleboard due to the material properties.
- Using special connectors (e.g., dowels, clips) requires modifying the panels, which can damage the material.
- Alternative systems like cam locks (eccentric connectors) are not intended for PLATSA.
My tip: If screws are considered too complicated, you might experiment with quick-assembly systems, but there is no guarantee of stability. Which modules exactly are you planning to apply this to? Shelves, cabinets, storage boxes? That can help discuss more targeted solutions.
NEILIR
2 Aug 2020 10:15
PLOMA schrieb:
Which exact modules do you want to implement this for? Shelves, cabinets, storage boxes?
Thanks for the hint, PLOMA. Specifically, I’m referring to the modular shelving units from the PLATSA series, which I often rearrange and ideally want to transport more easily. So, mostly large carcasses with doors.
My goal was to make assembly a bit more straightforward, ideally without always having to carry a screwdriver around. Plug-in connections or other quick-assembly methods would fit perfectly here.
I imagine that a precisely fitting plug system or at least an alternative to screws would make rebuilding easier during a move. Of course, without completely sacrificing stability. Are there any practical experiences or modifications you could recommend?
