ᐅ Are there long-term protection options for IKEA PLATSA furniture?
Created on: 23 Oct 2016 08:12
Jogau45
Good morning everyone, I have a detailed question: Are there any long-lasting protective options for IKEA Platsa furniture that can effectively prevent common issues like scratches, water stains, and general wear over time? I am particularly interested in whether the surfaces can be treated without compromising the design or functionality, and if such measures are truly sustainable in the long term. If anyone has practical experience or recommendations, I look forward to a thorough discussion.
A more detailed post on this topic:
The PLATSA components are mostly made of particleboard with a melamine resin coating, which means the surface is already relatively resistant to scratches, heat, moisture, and stains – but not indestructible.
Long-term protection can be divided into two categories:
1. Surface protection through care products:
- Plastic care creams (e.g., special furniture polishes) create a very thin film that fills in minor scratches and repels moisture.
- These products need to be applied regularly because mechanical wear will eventually remove the effect.
2. Physical protection through additional elements:
- Protective films made of transparent PVC or polyethylene. These films are custom-cut and adhered to the surfaces. They effectively protect against scratches and stains but are not visually perfect and, depending on quality, are not 100% permanent.
- Felt pads under cabinet feet or protective strips on heavily used areas help minimize mechanical damage.
Only covers or coasters help against objects standing wet for long periods, as melamine is not completely waterproof. By following these points, you can significantly extend the lifecycle of your PLATSA furniture.
Sealing with varnish or paint is not advisable because the glued joints are sensitive and the hard surface does not provide good adhesion.
How exactly is your PLATSA furniture used? For example, is it placed in a heavily used kitchen or in a living room?
TUELBA schrieb:
How exactly is your PLATSA furniture being used? For example, is it placed in a heavily used kitchen or a living room?Thank you for your detailed explanation! I have a PLATSA sideboard in my living room. It is mainly used to store media devices and books, so it is used daily but not directly in a damp area. The main issue is occasional water rings from glasses, and I've also noticed that the lighter surfaces tend to show small scratches quite quickly. I don’t want to repaint or refinish the furniture every year. Therefore, I am looking for a solution that remains fairly discreet and offers long-term protection.
labau schrieb:
For your living room sideboard, I recommend clear, self-adhesive protective films.Exactly! And: Be patient! At first, I also thought cleaning products couldn’t work wonders, but regular use really helps. Also, for water rings: I use small coasters – they look great and provide perfect protection.
Keep it up, you’ll manage it 🙂.
Hey, I can only confirm that! Protective films are great, and if you like to keep your furniture looking natural, this is the best invisible option! Additionally, I have two tips:
- You can prevent water stains by always placing something absorbent underneath.
- If you often sit on furniture with corners, edge protectors are also worth considering.
I have PLATSA myself and am very happy with these solutions!
nesau3 schrieb:
I have PLATSA myself and am very satisfied with these solutions!This shows that practical solutions always take priority. Regarding paints or further treatment, one should be cautious due to the factory-applied coating. Manufacturers usually advise against additional coatings, as they can affect the functionality of the furniture.
