ᐅ Are there any versions of Ikea Pax wardrobes available with glass doors?
Created on: 31 Mar 2018 14:07
mackmi
mackmi
31 Mar 2018 14:07
Hello everyone, I am considering purchasing a new PAX wardrobe system from IKEA. However, I am specifically interested in versions that have glass fronts instead of the usual wood or MDF fronts. My question is: Does IKEA officially offer PAX variants with glass fronts instead of wood or other materials? If so, what options for glass fronts (clear, frosted, tinted) are available, and do these fit easily onto the standard carcasses? I have searched online, but the information is sometimes contradictory or incomplete. Thank you very much for your help!
ritotar
31 Mar 2018 16:29
mackmi schrieb:
Are there official PAX variants at IKEA where the fronts are made of glass instead of wood or other materials?
Hi! Yes, although IKEA mainly offers the PAX system with solid fronts, there are indeed options with glass—usually in the form of display cabinet doors. These can be found as frameless glass doors or with wooden frames, often in clear or frosted glass.
Important to know:
- The glass doors are usually sold as accessories, so they are not part of the basic model but must be purchased separately.
- They fit easily onto the standard carcasses since the PAX system is modular and compatible.
- Options like frosted (milky) glass or clear glass are available; tinted glass is less common.
If you want a touch of elegance with functionality, the glass variants in the PAX range are really nice and great for living rooms or bedrooms. Like a wardrobe and a display cabinet in one. 😎
jelite
1 Apr 2018 09:44
ritotar schrieb:
You can find these at the front as frameless glass doors or with wooden frames, often using clear glass or frosted glass.
To add and explain a bit more:
IKEA’s PAX system actually offers two main types of glass doors:
- Display cabinet doors with clear glass set in wooden or metal frames, making your storage clearly visible.
- Frosted glass (milky glass), which provides more privacy through slight opacity but still allows light to pass through.
The doors are sold as separate fronts and fit the standard sizes of the PAX cabinet carcasses. Tip: Keep in mind that the hinges for glass doors may require different adjustments than those for solid wood doors—however, IKEA hardware is usually compatible.
Common mistakes I often see:
- Not checking whether the height and width match the carcass correctly.
- Not thoroughly reading the installation instructions for glass doors, since glass needs careful handling.
Summary:
- Yes, glass doors are available – both clear and frosted glass.
- Separate fronts compatible with standard carcasses.
- Pay attention to measurements and protect the glass during installation.
If you have specific questions about installation or sourcing, I’m happy to help!
Aimee
2 Apr 2018 18:53
mackmi schrieb:
Are there official PAX variants from IKEA where the fronts are made of glass instead of wood or other materials?
Yes, IKEA offers PAX doors with glass fronts. These are available as display cabinet doors with clear or frosted glass. They are sold separately and fit the standard frames.
