Hello everyone, I am currently planning a new wardrobe and considering the Ikea Pax series. I have a question: Are there any drawer options within the Ikea Pax system that offer particularly large storage capacity?
I am looking for the most spacious and efficient storage solution for clothes and other personal items, without having too many small compartments that unnecessarily limit the space.
Do you have experience with specific drawer models that maximize storage volume? For example, are there especially deep or wide drawers that differ from the standard options? Or perhaps alternative Pax accessories that I should consider?
I would appreciate as detailed and specific feedback as possible, as I want to finalize the planning soon.
Yes, the Pax drawers are available in different depths. The deepest drawers are about 50 cm (20 inches) deep. Additionally, you can vary the width and height to create more storage space. Often, it is worth choosing wide drawers instead of many small compartments. The exact measurements are available in the Ikea planner.
The question of maximizing storage space in Ikea Pax drawers is actually more complex than many people realize. Essentially, Ikea offers different drawer models for the Pax wardrobe that vary in depth from about 35 cm to 50 cm (14 inches to 20 inches). The maximum width for a single compartment is 100 cm (39 inches), which you should keep in mind during your planning.
An important point is that the drawer depth usually corresponds to the depth of the wardrobe itself: 35 cm (14 inches) for standard depths of 35 cm, and 50 cm (20 inches) for those that are 58 cm deep (23 inches). Choosing a 58 cm deep model automatically provides more storage space for the drawers.
Another aspect to consider is the side panels: drawers with greater depth often have slightly thicker side walls, which reduces storage space minimally but increases stability.
Besides classic drawers, you can also install so-called pull-out shelves or baskets, which offer more flexible storage options. These often have no fixed divisions, allowing you to use the space more efficiently.
My recommendation: if storage space is your top priority, opt for the 58 cm depth and choose wider drawers. The maximum height of the drawers is generally between 20 and 25 cm (8 to 10 inches), depending on how you combine them. This allows for storing larger items effectively.
To optimize your design, plan your Pax wardrobe using the Ikea planner, where you can easily compare different depths, widths, and heights. The specific article numbers that fit are also shown there.
Finally, a practical tip: many people forget that a combination of clothes rails, shelves, and wide drawers often results in the most effective use of storage space—relying solely on drawers is not always the best solution.
The topic of storage space in Ikea Pax drawers is definitely not straightforward. I used to feel that the standard drawers filled up quickly and weren’t used optimally. I’m glad this forum hosts such discussions because it helped me approach the wardrobe a bit more relaxed.
Sometimes it’s more about the impression of storage space than the actual cubic meters. Personally, I chose a combination of deep drawers (50 cm depth) and pull-out baskets. This feels much more spacious to me because it is more flexible to use.
This was also an emotional decision for me because I was worried the wardrobe would quickly become cluttered. Now I can say: better a few large drawers than many small ones. Domau0 is right when they say that is often more efficient.
I would also ask how you generally organize your clothes or items. Some find it practical to divide drawers into sections, while others just want open space.
If space is limited, it also makes sense to measure exactly how much depth and width you can use before planning. This makes choosing easier.
Regarding the question about drawers with especially large storage capacity in the Ikea Pax system, it should be noted that the storage space is primarily determined by the depth of the Pax wardrobe. There are essentially two depth options:
- 35 cm depth (14 inches)
- 58 cm depth (23 inches)
The drawers are designed to match the wardrobe depth accordingly. The 58 cm deep models therefore offer approximately 66% more space in depth than the 35 cm versions.
Additionally, the drawer width is limited by the Pax module widths, which are 50 cm (20 inches) and 100 cm (39 inches). A 100 cm wide drawer is possible, providing significantly more storage space than two narrower 50 cm drawers.
The drawer height is variable and can be adjusted depending on the interior layout of the wardrobe. Often, 20 cm (8 inches) high drawers are chosen when no taller storage is needed.
Using the Ikea online planner, which lists all dimensions and accessories, is recommended for planning.
It should also be considered that drawers have a metal frame or wooden slats on the sides, which cause a minimal loss of space. This should be taken into account when choosing the width and depth.
In summary: For maximum storage capacity, Pax wardrobes with 58 cm depth and 100 cm wide drawers are best suited. It is preferable to choose drawers as wide and deep as possible to optimize volume.
