ᐅ Are there adjustable wall brackets for the KALLAX that allow mounting above radiators?
Created on: 19 Jan 2021 09:17
Kaan38
Kaan38
19 Jan 2021 09:17
I have a specific question regarding the installation of my KALLAX shelf from IKEA. Due to the spatial conditions, I want to mount the shelf directly above a radiator on the wall. Unfortunately, this is not that simple, as the standard wall brackets are often rigid and sometimes either not tall enough or too deep.
My question: Are there flexible wall brackets or special mounting materials for the KALLAX that allow installation above radiators, providing enough clearance and adjustable fitting? I am looking for something like a spacer or an adjustable wall bracket that enables safe, stable shelf mounting above the radiator without direct contact.
I would appreciate any tips, recommendations, or even personal experiences with such solutions. Thank you!
NICOLELIS
19 Jan 2021 09:43
as far as I know, IKEA does not offer flexible brackets specifically designed for KALLAX units above radiators.
Alternatively, you can use wall brackets with spacers, which are available at hardware stores. These are usually adjustable and provide the necessary clearance.
Surela
19 Jan 2021 10:09
Good morning,
after reading your question about "Are there flexible wall brackets for the KALLAX to install above radiators?" I would like to provide a more detailed explanation. In fact, IKEA does not officially offer brackets specifically designed for mounting above radiators, because radiators vary in size and placement, so universal brackets usually do not fit.
The best solution is to use adjustable wall brackets or spacers. These allow variable depth for the bracket, so you can mount the shelf with enough clearance without obstructing the radiator. It is important to carefully measure the distance between the wall and the top edge of the radiator beforehand, and also consider the radiator shape – for example, round radiators require different bracket profiles than flat models.
For instance, there are angle brackets with adjustable-length rails or various pipe clamps that can be combined modularly as spacers, ensuring the shelf is securely mounted and does not affect heat circulation.
Have you already measured your radiator? What is the distance from the wall, and how far out should the shelf be mounted?
Kaan38
19 Jan 2021 10:27
Surela schrieb:
Have you already measured the radiator? What are the dimensions of the gap to the wall, and how deep should the shelf be mounted?
Thank you for the detailed answer. Yes, I have already measured the radiator: it is approximately 12 cm (5 inches) deep, about 8 cm (3 inches) away from the wall, and the height up to the underside of the windowsill is just under 60 cm (24 inches). The KALLAX shelf should be around 30 cm (12 inches) deep, with a maximum height of about 120 cm (47 inches).
It is especially important to me that there are no visible screw heads on the front, so I would prefer to use enclosed brackets that can hold the shelf securely and look reasonably neat. Are there such brackets that allow flexible depth adjustment, or is it more common to build custom supports using angle brackets and spacers?
NICOLELIS
19 Jan 2021 10:44
A self-build using angle brackets and spacers is the simplest solution.
For aesthetics, you can cover the screw heads with color-matched caps. This looks neat and is durable.
toril
19 Jan 2021 11:02
A structured response on the topic:
1. Creating spacing: Metal spacers are common, such as pipe clamps or spacers that are attached to the bracket.
2. Fastening: Screws should be anchored into wall plugs; use suitable anchors and pay attention to materials compatible with thermal insulation. Avoid damaging the radiator itself.
3. Appearance: Screw heads can be covered with caps. There are also brackets that are screwed into a groove, but these are rare.
4. Load: KALLAX shelves are relatively heavy, especially when filled with books, so pay attention to the minimum anchor size and bracket strength.
Conclusion: For flexibility, adjustable wall brackets with appropriate spacers are more practical than fixed IKEA brackets.
