ᐅ Kallax Shelving and Radiators – Heating Issues?
Created on: 27 Jun 2021 08:43
Ivanle
Hello everyone, I recently bought a Kallax shelf and plan to place it in my living room directly in front of the radiator. I am wondering: can the heat from the radiator affect the material of the Kallax shelf or cause any damage? I am especially concerned about whether the heat could impact the laminate or the joints in the shelf, as I have read that wood-based materials can swell or warp when exposed to continuous heat. What has been your experience? Has anyone encountered issues with 'Kallax and radiators – heat problems?' in practice, such as damage to the shelf or reduced heating efficiency? Thanks in advance for your experiences and tips!
Ivanle
27 Jun 2021 12:02
Thank you for the detailed responses! My radiator is a classic panel radiator, about 60cm (24 inches) wide, with a thermostatic valve. The surface temperature in winter is around 55 degrees Celsius (131°F), measured with an infrared thermometer. Unfortunately, air circulation is somewhat limited in my setup because the Kallax is placed almost against the window, and the radiator has slightly less than 10cm (4 inches) of clearance from the shelf. Do you have any tips on how I can improve air circulation without moving the entire shelf? Perhaps some kind of spacer or other solutions?
sarla
27 Jun 2021 12:27
Ivanle schrieb:
My radiator is a classic panel radiator, about 60cm (24 inches) wide, with a thermostatic valve. The surface temperature in winter is around 55 degrees Celsius (131°F).
At a surface temperature of 55°C (131°F), a distance of less than 10cm (4 inches) is indeed critical. Simple plastic or metal blocks can be used as spacers to slightly raise the shelf and create an air gap. It is important that these materials are heat-resistant and do not get damaged themselves. Additionally, small ventilation grilles can be installed in the Kallax unit to improve air circulation.
kloreo
27 Jun 2021 13:04
Use spacers made of silicone or heat-resistant plastic. Ensure proper air circulation. Avoid heat buildup!
Khalil
27 Jun 2021 14:22
I really like how you’re discussing the technical aspects! 🙂 I would support the tip about using spacers, as they create airflow and usually look good too. If you feel like trying it, just go for it—I was also surprised by how much of a difference it makes!
JAFUHAU
27 Jun 2021 15:10
I understand why you’re being cautious. Heat near furniture is always inconvenient, especially when you want to use the shelf for a long time. If you have already set up the shelf and some warmth occurs, I would recommend regularly checking the shelf for any warping or discoloration and, if necessary, moving it to a different location before any permanent damage happens. It’s not a problem to protect the furniture — better to be cautious than to deal with problems later on.
PLOMA
28 Jun 2021 09:40
Hello Ivanle, I wanted to add: If you are considering placing the shelf in front of the radiator for an extended period, a portable air circulation aid, such as a small fan, could help distribute the warm air better and prevent heat buildup. A reflective heat shield placed behind the radiator could also reduce radiant heat transfer. Depending on the room layout, a short-term investment might be worthwhile to protect both materials and the heating system. I’m also curious about the height of the shelf and whether you plan to store heavy items in it – the load capacity can decrease when exposed to heat.
