ᐅ Are there any differences in assembly between the various IKEA HEMNES models?
Created on: 1 Dec 2020 18:23
O
Onzar7
O
Onzar7
1 Dec 2020 18:23
Hello everyone, I am currently looking into the different IKEA Hemnes furniture models and planning to purchase a piece from the series. I am specifically interested in whether there are any differences between the HEMNES models regarding assembly.
Since HEMNES is a comprehensive range with various wardrobes, dressers, beds, and shelves, I am wondering if these pieces present different levels of difficulty for assembly or have any special requirements.
For example, are there models that are more complex to assemble due to their construction or that might require special tools? Or are the assembly instructions generally structured the same way and based on the same principles?
I would greatly appreciate any experiences or detailed advice, especially regarding whether some models require more time or patience to put together. Thanks in advance!
O
onMarcos
1 Dec 2020 20:37
Onzar7 schrieb:
I am specifically interested in whether there are differences between the HEMNES models regarding assembly.
Basically, the HEMNES series follows consistent assembly methods, especially using the familiar wooden dowels, pegs, and screws. However, depending on the model, there are differences that affect the assembly effort:
- Cabinets with many drawers (e.g., dressers) usually require longer, precisely adjustable drawer slides and more individual parts. Patience is needed when assembling the drawers.
- Beds and larger items often have bulkier components, which require more space and sometimes a second person.
- Shelves or open furniture are generally simpler because they have fewer complex connections.
Tip: Always follow the IKEA instructions step by step. The clear diagrams are so good that you rarely need extra tools, except for a Philips screwdriver (a cordless drill is recommended with caution).
A common mistake is fully tightening screws right away instead of first inserting them loosely – fixing errors afterward is difficult.
In summary, there are differences in assembly time and complexity, but no fundamentally different construction methods. If you have chosen a specific model, I’m happy to help you in more detail.
sarla
2 Dec 2020 09:12
In addition to the previous answer: The differences in assembly within the HEMNES models mainly result from the size and number of individual parts.
- Dressers with multiple drawers require precise alignment of the drawer slides, which makes assembly more challenging.
- Large wardrobes or beds often also need to be secured to the wall to ensure stability.
No special tools are needed beyond a simple screwdriver and possibly a hammer for wall plugs.
It should also be noted that IKEA instructions have been standardized in recent years, so the assembly principles for HEMNES are consistent. The material quality of the fasteners is uniformly the same.
Good preparation (sorting the parts, reading the instructions before starting) minimizes frustration.
If anyone has specific experience with certain HEMNES furniture, tips on handling the drawer slides or wall mounting would certainly be helpful.
rickey
2 Dec 2020 19:44
sarla schrieb:
It should also be noted that IKEA instructions have been standardized in recent years, so the assembly principles for HEMNES are identical.
That's exactly what I noticed as well. However, at first, I had some doubts about whether I was putting the many parts of my HEMNES dresser together correctly, and I was a bit nervous about the time.
I deliberately took my time and took breaks in between, which helped a lot. I also recommend assembling with at least two people, especially for larger parts or if you’re not very experienced.
Onzar7 schrieb:
Are there, for example, models that are more complicated to assemble due to their design or that might require special tools?
From my experience, the larger cabinets with many drawers and a somewhat bulky construction are particularly demanding. You don’t need special tools, but good lighting and enough space are essential.
So don’t worry—although it requires effort, it’s doable with the instructions and some patience!
Le_kin
3 Dec 2020 07:58
This is a very valid question, especially when planning the assembly efficiently. The differences become noticeable when considering the following factors:
- Size and weight of the components: Larger HEMNES parts, such as the bed frame model or large wardrobes, require a certain amount of strength and space during assembly, so having a second person assist is often helpful or necessary.
- Drawer systems: Various models use different types of rails (metal glides or simpler plastic runners), which vary in ease of assembly and adjustment depending on the model. Precise installation of drawer slides is considerably more complex for models like the five- or six-drawer chests than for smaller pieces.
- Wall mounting: Some HEMNES models come with slightly different wall mounting hardware. Although the basic concept is similar, mounting brackets or the types of screws used differ slightly. It is always important to consider the wall type.
- Assembly instructions: The basic structure of the instructions is similar, but models with more detailed parts have significantly more extensive and complex manuals.
- Tools: Commonly required tools include a Phillips screwdriver; a cordless drill with torque control is useful but not essential. No HEMNES model requires specialized tools.
If you already have a specific model in mind, the part number in the instructions often gives hints about the assembly complexity. Feel free to ask which particular piece of furniture you are interested in so I can provide more precise advice.
