ᐅ Are there any tips for stabilizing Ikea PLATSA furniture after assembly?
Created on: 12 Aug 2018 09:13
falkto
Hello everyone, I recently assembled some Ikea Platsa furniture and noticed that it feels somewhat unstable at times, especially when the modules are combined rather than standing alone. Therefore, I’d like to ask the community: Are there any proven tips or methods to stabilize PLATSA furniture after assembly? Just to clarify – I followed the assembly instructions exactly, but I’m mainly interested in options beyond the standard approach to make the furniture secure and permanently stable. I’m looking forward to your experiences and suggestions – practical tricks that have worked for you are especially welcome.
falkto schrieb:
So far, I haven’t fixed the furniture to the wall, which I now consider sensible, but I’m also looking for ways to make the modules connect more securely on their own first, without drilling right away.It’s understandable that you prefer to avoid wall mounting initially. For stability between modules, I recommend ensuring a precise fit of the dowel joints and additionally using high-quality corner braces inside the junctions. They provide strong support and remain hidden when installed internally. Make sure to use screws rated for the expected load.
If you want a minimally invasive method, construction adhesive applied at the joints can also help, but note that this is not reversible. A stable connection primarily depends on proper execution and tightening of the fasteners.
Hello falkto and everyone else, I completely understand the frustration with wobbly furniture – who wants a secret shaky dance party at home?
A few tips on this – and don’t worry, I’ll stick to stability advice without any complicated tricks:
- First of all: wall mounting, which definitely provides support, is Platsa’s best friend. But I know you want to try it without drilling first.
- Between the modules, sometimes a pressure washer... wait, no vacuum cleaner here! Seriously though, small metal brackets inside, as mentioned before, really help a lot.
- A nice trick: stick rubber bumpers or small anti-slip pads on the bottom corners. They prevent any sliding, even when you open the doors.
- If the back panels are just thin fiberboard nailed on, it often helps to replace the nails with small screws that you can better control at home.
And if there’s ever a small stone or something similar under the furniture – get rid of it! That already makes a noticeable difference.
So, I say: have some fun upgrading your furniture, and the PLATSA will stand firm – no bungee cords or nails in the face necessary.
