ᐅ Are there any tips for assembling Ikea PLATSA units?
Created on: 3 May 2020 08:37
Jaloreo
Jaloreo
3 May 2020 08:37
I am planning to get an Ikea Platsa system soon and am looking for tips on the best way to combine different PLATSA units. The modules are very flexible, which I really like, but I want to avoid running into problems later because I chose the wrong sizes or combinations.
I’m especially interested in what to consider regarding measurements, wall mounting, weight loads, and interior layout to ensure the unit is stable and functional. Also, are there any proven strategies for cleverly combining different modules without creating a visually cluttered look?
Perhaps some of you have personal experience with PLATSA or even creative ideas for custom configurations. I would also appreciate advice on what to keep in mind for special requests or securing the units to various types of walls.
Thanks in advance for your support!
hauklo
3 May 2020 09:12
Basically, I recommend measuring carefully and checking the wall structure before starting the planning. PLATSA elements are modular but quite heavy, so a secure wall attachment is essential. For drywall (plasterboard) walls, you should use special anchors; otherwise, stability issues can arise quickly.
For planning:
- Focus on width and height as priorities, avoid mixing too many different elements
- Plan the interior fittings according to their intended use (e.g., drawers for small items, open shelves for decorations)
- Adhere to the maximum load capacity of each module (Ikea provides these values)
- Visually, a uniform color and front design is recommended to create a calm overall appearance
In general, it helps to do the planning using Ikea’s online planner, where you can also see the fit and harmonious sequence.
Additionally: Always secure a chain of multiple modules firmly to the wall to prevent tipping hazard.
lochen
3 May 2020 10:45
To add to hauklo’s tips:
- Use IKEA’s PLATSA planner extensively and start by selecting the room dimensions in the planner. This lets you realistically check which combinations will fit.
- For the interior layout, mixing drawers, doors, or open shelves makes sense; transparent or light-colored fronts are often a good option if you want to avoid a bulky look.
- Make sure to account for the required plinth height that PLATSA calls for (typically 15 cm (6 inches)), which can be important if you want the units to be flush with each other.
- Consider well-planned cable outlets if you plan to use the shelves for media devices.
A small tip: If you intend to stack several modules on top of each other, be sure to fix them together internally with screws from the accessories to ensure the necessary stability.
V
Victor54
4 May 2020 07:28
I find it interesting that so far there has been a lot of discussion about stability and planning, but hardly anything about the material quality and long-term durability of PLATSA sets. Has this perhaps already been discussed in detail in any user reviews?
hauklo schrieb:
PLATSA components are modular but quite heavy, so a secure wall mounting is essential.
Could you elaborate on this? How heavy are individual modules approximately, and how do different wall types affect the mounting?
In addition, I believe the flexibility of the back panel should also be considered, as for some modules it consists only of a thin particleboard and might not withstand much load or pressure. Would reinforcements be advisable here?
I am skeptical about relying solely on wall anchors in drywall, as there is often no mention of additional reinforcement, for example with metal profiles. Shouldn’t this definitely be added?
naujon
5 May 2020 16:03
These are good questions, and regarding planning and assembly, I have a few detailed tips that I’d like to share as a brief guide:
- Preparation: Measure the space precisely and, if possible, sketch a floor plan on the wall. This helps in estimating the maximum dimensions. Keep in mind that PLATSA units also require wall mounting, so note the exact type of wall.
- Online Planning: Use the Ikea PLATSA planner. Here you can customize modules, select colors, and get guidance on the overall size.
- Module Selection: Try to avoid mixing too many different module types to maintain a calm appearance. A combination of closed units with doors and open shelves usually looks harmonious.
- Fixing: For standard brick walls, conventional wall plugs are sufficient. Drywall (plasterboard) requires heavy-duty anchors or cavity anchors. Always check the maximum weight capacity of the module and choose fixings accordingly.
- Interior Configuration: Consider what you want to store on the shelves. PLATSA offers drawers, flap doors, and open shelves. Keep in mind the load capacity of the shelves.
- Reinforcement: If you plan to stack multiple modules, be sure to use the connecting screws between the units and strictly implement wall mounting. Some users also add extra brackets.
- Design: Uniform fronts and colors help keep the room visually calm.
Summary: Accurate measurement, planning, appropriate fixing, and clear module selection ensure a good result. If you specify the wall type (e.g., brick, drywall, concrete), I can provide more specific advice.
