ᐅ Are there any tips for assembling IKEA Hemnes furniture on uneven floors?
Created on: 9 Feb 2015 08:27
gukau61Hello everyone, I am planning to place my new IKEA Hemnes secretary desk in my home office on a slightly uneven wooden floor. The unevenness is not severe, but noticeable enough that the piece of furniture wobbles slightly and doesn’t sit completely flat. Are there any proven tips or established techniques to stabilize and level the Hemnes desk despite this? I don’t want to have to keep adjusting it constantly and would also like to avoid damaging the floor. Perhaps some of you have experience with this furniture on uneven surfaces and can recommend suitable materials, tools, or small aids for leveling. Thank you in advance for your helpful advice!
Hello gukau61, your concern is completely understandable, as even slight floor unevenness can cause stability issues with furniture. The feet on Hemnes furniture are generally sturdy but usually not height-adjustable. I recommend first measuring the actual height difference precisely with a spirit level, as it can sometimes be underestimated. There are several ways to compensate for this: - Adjustable furniture glides or feet: Some hardware stores offer special screw-in feet that can be height-adjusted, and you can mount these under the Hemnes feet. - Felt, cork, or rubber pads: For smaller height differences, you can layer these materials in different thicknesses underneath. - Wooden wedges: Properly cut small wooden triangles can also be placed between the floor and the furniture — they provide good stability but require some maintenance to prevent slipping. - Additionally, it is important that the furniture piece is securely fixed, for example screwed to the wall if the model allows — this helps prevent tipping hazards. Please also make sure not to place the adjustment aids on carpet or similar surfaces, as this reduces their effectiveness. If you like, I can provide more details about specific products. How uneven is the floor exactly?
IANLAU schrieb:
Please also make sure not to place the tools on carpet or similar surfaces, as this would affect the purpose of leveling. Thank you for the advice. The Hemnes is actually on bare wooden flooring, so gliders or felt pads are possible. The unevenness at the critical corner is approximately 4 to 5 millimeters (0.16 to 0.20 inches), measured with my spirit level. Your suggestions about adjustable furniture feet or wooden wedges sound reasonable. Could you please describe the adjustable furniture feet in more detail? Would I need to modify the underside of the furniture for this? Also, how is their load capacity, especially for a large desk unit like the Hemnes?Hello gukau61, I’d like to answer your question in more detail, as I have a lot of experience with arranging furniture on uneven floors. For an uneven surface of 4-5 mm (0.16-0.20 inches), it is indeed advisable to adjust the furniture feet accordingly. The standard feet of the Hemnes series are not height-adjustable, but there are several practical solutions:
- Adjustable furniture feet: These screw-type feet, often with a threaded spindle and washer, are mounted under the furniture legs. You remove the original small felt pads and instead screw the new feet into the existing dowel holes or directly fix them to the underside. It is important to check the attachment points in advance to ensure stable mounting.
- Rubber buffers and felt pads: When combined, they provide slight slip resistance and protect the floor. These are suitable for unevenness up to 2 mm (0.08 inches), but less so for larger deviations.
- Self-adhesive cork pads: Often used for minimal level differences and can be stacked in multiple layers.
- Wooden wedges: The simplest solution, but the wedge must fit very precisely to avoid permanently tilting the furniture and should have a non-slip backing.
Additionally, you should check whether the furniture can be secured to the wall – Hemnes furniture often has corresponding drill holes. Wall mounting prevents tipping and provides additional stability. This is especially recommended for a secretary desk, which may be loaded and moved from time to time.
Do you have more information about the floor type (e.g., wood species, surface) or have you already tried any small aids? This way, we could refine the solution further.
Hey gukau61, I can only say: go ahead and don’t hesitate when assembling it! Especially on slightly uneven floors, a few adjustable feet make a huge difference. I fitted screw-in furniture glides on my Hemnes – fantastic, no more wobbling and better protection for the floor 😊! Don’t get discouraged, sometimes the best approach is just to try it out and fine-tune as needed. Good luck, and feel free to reach out if you need more tips!
