alcibiad6427 Feb 2016 09:17Hello everyone,
I am currently looking into the IKEA PAX wardrobe and its wide range of customization options. Since the PAX series is quite modular, I’m wondering if there are any specific IKEA hacks that can significantly enhance the functionality or appearance of the PAX wardrobe beyond the usual assembly tips.
I am particularly interested in ideas for optimizing the interior layout, additional functional elements that can be integrated by yourself, as well as creative solutions for better space utilization or for specific use cases such as office supplies, technology, or walk-in closets.
Is there anyone here who may have personal experience with unusual modifications or hacks for the PAX? Insights on the materials used, tools required, or the level of difficulty would also be appreciated.
Thanks in advance for your tips and suggestions!
Hello alcibiad64,
Regarding PAX hacks, there are actually many possibilities, especially because the system is so versatile. A few of my favorite ideas are:
- Using additional shelves made of LED-lit glass to create an elegant display and improve visibility.
- Integrating pull-out drawers with specialized inserts, for example for jewelry or office supplies.
- Attaching magnetic strips or hooks to the inside of the doors to keep small items organized.
For the implementation, you might want to have a jigsaw and a drill ready, depending on how extensive the modifications are. It’s not particularly difficult, of course, if you follow the included assembly instructions carefully and work cautiously.
If you want more detailed advice on materials or steps, just let me know.
alcibiad64 schrieb:
I am especially interested in ideas to optimize the interior layout, additional functional elements that can be integrated by yourself, as well as creative solutions for better space utilization or specific use cases such as office supplies, technology, or walk-in wardrobes.
Hello alcibiad64,
to address your question about special IKEA hacks for the PAX wardrobe more thoroughly, I’ll start with space optimization:
1. Interior Layout: The PAX frame can easily be enhanced with VARIERA inserts or modules. For technology, narrow cable channels are useful; these can be integrated on the sides or even in the base. This way, small speakers or charging stations can be hidden out of sight. It is important to plan the cable routing carefully and create cutouts in the carcass, but be sure not to compromise the stability.
2. Additional Functional Elements: One trick is recessed LED strips that are controlled via a door contact switch, so the wardrobe stays dark at night when the door is closed. For a workspace, you can also install a pull-out work surface in a row of cabinets, with drawers next to it for office supplies.
3. Visual Improvements: For example, I once saw a version where the doors were enhanced with decorative raw wood slats and handles from a DIY store—this creates a rustic style while fully preserving the PAX functionality.
I would like to know which room the wardrobe is intended for in your home and whether you have already selected specific components like drawers or doors. That way, we can discuss the hacks more precisely.
Good morning everyone,
Here is a structured overview of proven hacks for IKEA PAX wardrobe systems, based on personal experience and numerous installations:
- Interior organization: Adding VARIERA inserts for clear sorting of small items such as accessories or tools.
- Lighting: Installing LED lights with motion sensors that can be easily mounted inside without much effort.
- Space utilization: Combining multiple frames with a single door front (e.g., sliding doors) to create a unified look and maximize storage capacity.
- Doors: Customizing with films or replacing fronts for a personalized design, while checking if the doors still fit and the hinges remain compatible.
- Technical integration: Planning cable pass-throughs for charging stations or smart home controls, for which precise measurement and planning beforehand is recommended.
All in all, PAX wardrobes can be well customized as long as the basic structure and assembly instructions are followed.
If anyone is aiming for a specific idea, I am happy to offer suggestions regarding feasibility and safety.
Ianlau schrieb:
For the implementation, you might want to have a jigsaw and a drill ready, depending on how extensive the modifications are.I can only confirm that! I just worry that some of the bigger alterations can get a bit more demanding from a craftsmanship perspective. An example from my experience:
- I installed LED strips under the top shelves, which required mounting cable channels on the back panel of the cabinet and rerouting the power supply accordingly.
- Additionally, I partially replaced doors with mirrors that I cut myself (be careful with screw holes and stability!).
If you don’t have much experience with DIY work, I recommend testing on individual shelf parts first. Many IKEA materials are not solid wood but laminated particleboard, so you need to be very careful to avoid any damage or tearing.
