ᐅ How can Ikea Pax wardrobes be expanded with additional hooks and baskets?
Created on: 16 Jun 2022 08:37
thorben64
thorben64
16 Jun 2022 08:37
Hello everyone, I am considering expanding my IKEA Pax wardrobe with additional hooks and baskets because I need more storage space and better organization for accessories and smaller clothing items. However, I am unsure which types of hooks and baskets are best suited and how to attach or arrange them effectively within the wardrobe system without affecting stability or appearance. Does anyone have experience or tips on which additions work particularly well to make the IKEA Pax flexible and functional? I am especially interested in practical solutions for hanging extra hooks or baskets on the existing frame or doors. Thanks in advance!
gasidney
16 Jun 2022 09:12
For additional hooks, metal hooks that can be hung on the existing rails of the Pax system are suitable. Baskets are best as wire baskets, which can be slid into the rails. This allows for flexible arrangement of everything.
GiRoyce
16 Jun 2022 10:45
Hello thorben64, I am very familiar with your situation. When expanding the IKEA Pax system, it is important to first check the existing mounting options. Most users rely on original IKEA accessories that are precisely designed for the system – for example, VARIERA hooks or VARIERA wire baskets, which fit perfectly into the cabinet profiles. If flexible mounting solutions are needed, self-adhesive hooks on the inside of the doors can also work, but you should pay attention to the weight. Some also use basic grid systems or perforated panels to better organize hanging accessories. It is important not to exceed the load capacity to ensure the frame remains stable. You might also consider combining additional shelves with special hook rails to optimize space usage.
JAFUHAU
16 Jun 2022 14:03
I completely understand how frustrating it can be when the standard IKEA solution isn’t quite enough and you need more practical use. I had a similar experience with my Pax system. What helped me was actually equipping the inside of the cabinet doors with several small rows of hooks. This way, I had quick access to belts, jewelry, and small bags. Admittedly, I was initially unsure if it would look good, but with simple metal hooks, it looks very neat. And if you’re worried that the doors might become too heavy because of the weight, you can distribute the load evenly. Maybe this could work for you too?
ANMARCOS
16 Jun 2022 17:29
I think it’s overrated to always use only IKEA accessories. Sure, they fit well and look neat, but why not try something outside of the comfort zone? Who says you can’t use other hooks or baskets that you might find from different furniture manufacturers or hardware stores? For example, you could screw in sturdy stainless steel hooks that hold much more weight than the standard IKEA items—and replace the baskets with larger models that can be attached to the side panels using appropriate brackets. This might not be IKEA-compliant, but it’s definitely more flexible. Of course, you need to pay attention to stability and might have to drill additional holes or make adjustments yourself, but that’s what makes it interesting!
Benge5
17 Jun 2022 07:51
When expanding the IKEA Pax system with additional hooks and baskets, several factors should be considered: First, the type of mounting, since not all baskets and hooks are fully compatible. Most original IKEA accessories are designed to fit into the pre-installed rail systems or door profiles. For retrofitting without original parts, screw mounting on stable surfaces is recommended to avoid stress. Wire baskets are preferred because they are lightweight yet sturdy, and they also prevent moisture buildup. Alternatively, hanging hooks with rubber coating provide better grip without damaging the material. When distributing the additional elements, care should be taken to evenly distribute the load to prevent deformation.
