ᐅ Are there alternative back panels available for replacement in the KALLAX unit?
Created on: 20 Nov 2023 17:23
fonene
fonene
20 Nov 2023 17:23
I recently took a closer look at the popular IKEA KALLAX shelving unit and am considering replacing the back panels to make it a bit more personalized and sturdy. So my question is: Are there alternative back panels that can be used in the KALLAX instead of the original particleboard panels? I am interested in other materials as well as possible sources beyond IKEA’s offerings. It is important to me that the back panel is easy to install and fits well visually with the overall look. Does anyone have experience with alternatives or recommendations? Thanks in advance!
BiDennis
20 Nov 2023 18:02
fonene schrieb:
Are there alternative back panels to replace the original particleboard in the KALLAX?
Hello fonene,
That’s a great question, and I’m happy to provide a detailed answer: Yes, there are actually several options you can use instead of the original back panel in the KALLAX. For example, some people use sturdier MDF panels instead of the thin particleboard, which you can have cut to size at hardware stores. MDF is much more durable and can be easily customized with paint, adhesive films, or even fabric.
Alternatively, you can find flexible back panels made of plastic or thin plywood, which are often self-adhesive or can be fixed with nails. If appearance matters, there are also decorative back panels designed to resemble sliding doors or covered with patterned adhesive films.
The most important factor for replacement back panels is the right thickness: 3-4 mm (0.12-0.16 inches) is ideal so they fit into the existing grooves.
If you are handy, you could also make your own back panels by covering them with fabric or combining them with cork sheets. Many food stalls or creative workspaces use alternative back panels for added stability and style.
I hope this helps make your decision easier – if you like, I can also share some sources or specific material recommendations!
kautra
20 Nov 2023 18:17
BiDennis schrieb:
MDF boards that you can have cut at the hardware store
Exactly, MDF usually works well, just make sure to use a thickness of 3-4 mm (about 0.12-0.16 inches).
Note: avoid plywood, as it is often too thick.
Apply self-adhesive films for a decorative finish, if desired.
Katan
21 Nov 2023 09:48
Hello everyone! 😄
I’ve also switched to alternative back panels – I used thin cork boards fixed in place with spray adhesive. It immediately gives the shelf a cozy feel and also dampens noise a bit, which is helpful if someone uses the shelf as a room divider.
Another nice aspect is that the cork surface can be decorated or written on individually – a small bonus for creative minds. 🙂
If you want something more durable, MDF boards are definitely the better choice because of their stability. You can also easily paint them or cover them with wallpaper if you don’t want a natural look.
And don’t worry, installation usually doesn’t require much screwing – just carefully slide or glue them in place.
So my recommendation is: don’t hesitate to experiment with different materials, the shelf is really versatile!
fonene
21 Nov 2023 12:05
kautra schrieb:
Note: no plywood, it is often too thick.
Thanks for the tip! I hadn’t considered that and probably would have failed trying.
BiDennis schrieb:
The most important thing for replacement back panels is the right thickness: 3-4 mm (0.12-0.16 inches) is ideal
That clarifies things.
I’m also interested if anyone has ever customized a back panel themselves, for example, with photo printing, wallpaper, or fabric covering? I imagine it could look very appealing, but I wonder about the durability in everyday use and how it could be attached.
Jukin
22 Nov 2023 07:36
fonene schrieb:
I’m also curious if anyone has ever customized a back panel themselves, for example with photo prints, wallpaper, or fabric coverings?
Hello fonene,
I have actually done that before. I had 3 mm (1/8 inch) MDF cut to the exact dimensions of the Kallax unit and then covered it with self-adhesive vinyl featuring a photo print. It looks great and is quite durable.
As an alternative to vinyl, you can also use leftover wallpaper and attach it with waterproof wood glue. This will hold up well over time and offers a custom look.
I do have concerns about fabric, though, as it might loosen or collect dust over time. I would only recommend fabric if it is stretched very tightly and securely fixed— for example, with double-sided tape and additional framing.
In general, replacing the back panel in a Kallax unit is quite straightforward; the key is that the measurements must be exact and the new panel not too thick, otherwise it won’t fit.
If you like, I can write you a step-by-step guide on how I did it.
