Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
I'll start.
KfW 55 standard
COP 3.88
Alessandro10 Feb 2021 14:48Alessandro schrieb:
It's the same for me. I don't know why either...
Within one hour, the return flow drops by 3°C (5.4°F)So much for: Your screed stores much more energy than your buffer :p :p :p :p :p
T_im_Norden10 Feb 2021 15:02If the return flow drops quickly and significantly, the causes may be:
Hydraulics
Buffer tank
The screed has this temperature
Missing insulation
Hydraulics
Buffer tank
Missing insulation
Bookstar schrieb:
I would say the minus 3 degrees outside temperature 🙂. But you have that as well, so that wouldn’t be an explanation.Exactlyhalmi schrieb:
Is your UV completely closed?Great point you bring up! According to three different HVAC technicians, it must never be fully closed, because during defrosting the flow rate would not be sufficient. I didn’t believe it at first, but they were right.
I constantly had defrosting issues because the minimum flow rate couldn’t be maintained.
Bookstar schrieb:
Great point you bring up! According to three different HVAC technicians, it should never be fully closed because during defrosting the flow rate would then be insufficient. I didn’t believe it at first, but they were right.
I kept having defrosting issues because the minimum flow rate couldn’t be reached. Then it’s more likely that your hydraulic settings are incorrect, and a supply temperature of 28°C (82°F) is quite high for a modern house. I use 25°C (77°F) / 21°C (70°F) / 0 for a KfW 70 standard.
That would also explain the rapidly increasing return temperature.
