Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
I'll start.
KfW 55 standard
COP 3.88
T_im_Norden2 Feb 2021 14:1890 kWh is, in my opinion, too much at 1 degree Celsius (34°F) outdoor temperature.
At -8 degrees Celsius (18°F), I had 60 kWh.
T_im_Norden schrieb:
In my opinion, 90 kWh is too high at an outside temperature of 1°C (34°F).
I had 60 kWh at -8°C (17.6°F). The house is very well insulated, airtight, and dry. Everything has been verified according to the KFW55 standard. So, there should be no issues with the building envelope. Ventilation behavior is normal to very low, due to the use of a controlled mechanical ventilation system.
The house is freestanding and it’s quite windy, etc. But does that make that much of a difference? I’m not sure.
Do you have any ideas?
T_im_Norden2 Feb 2021 16:10Create a new thread.
In it, write the following:
Current supply/return temperatures
Room temperature in the rooms
Floor heating design according to the heating installer
Heating load according to the heating installer
Number of control valves
Number and length of heating circuits
Controller active or not
Heating circuit settings/flow rates
Buffer tank yes/no
Circulation yes/no
Daily heating runtimes in hours and number of starts (please no charts)
Whether you have already performed a hydraulic balancing, and if so, what your numbers were before.
Buffer tank yes/no
Circulation yes/no
