ᐅ 10x10 m urban villa (approximately 1,670 sq ft, 6 rooms), fine-tuning welcome
Created on: 20 Aug 2017 14:34
Changeling
Ground Floor:
Upper Floor:
Outdoor Areas:
Positioned on the Plot:
Development Plan / Restrictions:
The plot may only be built on the southern half; otherwise, there are no particular restrictions.
Plot size: 900 square meters (approx. 30 x 30 meters / 98 x 98 feet)
Slope: No, only on the west side does the land slope down 3 meters (10 feet) toward the street at the end of the plot. On the north side, there is a retaining wall because the plot is about 2 meters (7 feet) above street level there. Therefore, access by vehicle is only possible from the south.
Clients’ Requirements
Style, Roof Shape, Building Type: A two-story urban villa with a pyramid hip roof (square hipped roof), since the upper floor has no sloped ceilings.
Basement: No basement, as it is too expensive, impractical, and involves additional construction risks.
Number of Occupants, Age: 2 adults (30 years old), 1 child (3 years old), with 1-2 more children planned.
Living Room: A large, open living area was important to us as this is where life happens. A computer corner is planned in the lower right corner since we spend more time at the computer than watching TV. We also work a lot from home and do not want to be confined to a separate room.
Fireplace: Yes.
Guest Room: Also used as storage space, which is especially useful since there is no basement.
Kitchen: The stove and sink are not in their final positions yet – a cooking island is undesirable because of the extractor hood and impractical due to splashing.
Technical / Utility Room: Also serves as a pantry and should be filled with shelves up to the ceiling.
Children’s Rooms: Size should be adequate.
Bedroom: Almost too large, but necessary due to the large wardrobe and double bed.
Bathroom: The design is still at an early stage; for example, the shower is planned as a built-in enclosure without a cabin.
Terrace: Important to us, along with a covered area so we can leave items outside occasionally.
Garage, Carport: As large as possible! It should be a wooden carport, fully closed at the front with sectional doors, and open or closed at the rear as needed. We currently use our garage as a "second living room" and for storing garden tools and similar items. Due to the long car, space will be tight; likely the terrace will be slightly smaller and the carport deeper (or the roof overhang on the left extended). The additions on the far left are planned later as a garden shed or similar and are therefore not a fixed part of the house. The covered connection to the house is a must, so we can enter without getting wet. The lower part facing the street is purely for privacy and is not a solid wall.
Garden: We will build our greenhouse ourselves as we have it now.
House Design:
Planning by: Planner from a construction company; outdoor areas added by us.
What do you particularly like? Why?: The numerous outbuildings and large carport for space, the large living room with open kitchen (also for space). Also, the level access to the terrace (which we don’t have currently).
What do you dislike? Why?: The basement level feels a bit cramped (utility room/kitchen small), while the upper floor is very spacious, but so far this is the best solution.
Cost Estimate by Architect/Planner: $290,000 USD with a maximum of +10% overrun.
Insulation / Construction: Unfortunately, it is built only to the 2016 Energy Saving Ordinance (EnEV) standards; I would have preferred better insulation, but it is likely too expensive. The masonry consists of calcium silicate blocks (20 cm / 8 inches outside + 16 cm / 6 inches EPS (polystyrene) insulation boards).
Heating System: Ground-source heat pump (brine-water) with earth probe; gas connection would be too expensive and we do not want oil heating.
If you had to give up features / expansions
- Could you do without: At most one fewer children’s room; the rest should stay as is...
- Could you not do without: Everything? That would be difficult.
Why did the design turn out the way it is?
We reviewed suggestions from the planner, spent a weekend designing alternatives ourselves, and ultimately found the current compromise. It includes essentially all our wishes.
The design could have been better if the house orientation had been different; otherwise, the kitchen/terrace/dining area wouldn’t all have to be squeezed next to the carport. However, since the street is on the south side and the northern half of the plot cannot be built on, the house must be positioned as it is and the terrace on the south side to catch the sun. We do not want the carport on the east side, as that would place the house further toward the center of the plot and make the terrace fully visible from the neighboring house to the south.
A similar-sized building plot on the east side will be developed with another single-family urban villa.
What is the most important / fundamental question regarding the floor plan in 130 characters?
What do you think? What could be improved or is missing? Any concerns?
Upper Floor:
Outdoor Areas:
Fireplace: Yes.
House Design:
77.willo schrieb:
The use of punctuation is specified in DIN 5008. DIN 5008 has been the most overlooked standard for 5008 years, merely annoying office administration trainees. So, it's really expert trivia. In fact, it should be called 500/8, because in 500 years you’ll only receive eight letters that fully comply with this standard. That says a lot about the normative power of facts.
winnetou7822 Aug 2017 17:57It may be that I have confused something, but a house without these two things also complies with the standards according to your nice regulation.
winnetou7822 Aug 2017 17:59And that is what I will remain, just for you.
I’m sharing this standard design for reference. Although the bathroom is located above the open-plan living area, looking at the latest floor plans from other providers, this no longer seems to be an issue. The footprint is 10 x 10.25 meters (33 x 34 feet), which is the smallest I could manage.
But somehow it feels a bit dull, doesn’t it? It lacks personality. I need to keep brainstorming.
Changeling26 Aug 2017 22:16A controlled residential ventilation system is probably not financially feasible.
However, I am wondering why the house is so expensive, because when I compare here in the forum and with other (somewhat less reputable) builders, there seems to be more flexibility in the pricing with similar features. Hmm.
I will talk to the developer and request a detailed cost breakdown.
We were told that we need a minimum distance of 3 meters (10 feet) from this road, but I don’t know more than that...
I really like the upper floor! However, that’s usually not a problem with most floorplans. The ground floor is often too small. Here I miss a computer nook in the living room, a pantry next to the kitchen, and a shower in the guest bathroom. Maybe those can still be incorporated somehow.
Otherwise, really good! Many thanks for that.
In the last few days, I tried another version based on this design. What bothers me is primarily the interior guest bathroom and the somewhat more complicated layout upstairs. What do you think?
Overview? – no, sixteen federal states. A pedestrian and driveway is a public road accessible mainly to residents (completely legal), usually without a sidewalk, and often not considered a street regarding carport setbacks. A private road is a private property developed with a street.
kaho674 schrieb:
I’ll throw in this standard design. It does have the bathroom above the open living area, but judging by the latest floorplans from other providers, this no longer seems to be an issue. 10 x 10.25 m (33 x 34 feet) – I couldn’t get it any smaller.
But somehow it’s boring, isn’t it? It lacks character. I’ll have to work on it some more.
