ᐅ Floor plan 175 sqm gable roof without basement
Created on: 24 Feb 2023 20:55
s_mhofma
Plot size: 612
Slope: No
Floor area ratio
Plot ratio
Edge development: Yes. Construction directly on the street and 3 meters (10 feet) distance to neighbors on each side, so no flexibility in width
Number of floors
Roof type: Gable roof, 30 degrees pitch
Architectural style
Orientation: West/East
Maximum heights / limits: 3 meters (10 feet) distance to neighbors on each side, so no flexibility in width
Further requirements
Homeowners’ Requirements
Basement, floors: No basement, 2 floors, knee wall 1.80 m (6 feet)
Number of occupants, ages: 2 adults, 2 children
Office: Family use or home office? Home office
Overnight guests per year: Many
Open or closed architecture; open
Traditional or modern design
Open kitchen, kitchen island: Kitchen with island and concealed pantry
Number of dining seats: 8
Fireplace: No
Music / stereo wall
Balcony, roof terrace
Garage, carport: Garage
Utility garden, greenhouse
Other wishes / special features / daily routine, including reasons why certain things are or are not desired
Designer: Architect
- Planning company
- Architect
- Do-it-Yourself
What do you not like? Why?
Personal budget limit for the house, including fittings:
Preferred heating technology:
If You Have to Give Up on which details / expansions
- can you give up:
- cannot give up:
Why Is the Design the Way It Is? For example:
The house is located directly on the street. Distance to the neighbors on both sides is 3 meters (10 feet), so no possibility to adjust the width.
The entrance is on the side. Since the house faces the street, the living room, dining area, and kitchen are planned on the north side, facing the garden. All other rooms face the street side. Knee wall is 1.80 m (6 feet), roof pitch 30 degrees. Bedrooms and bathroom also face the garden side.
The pantry is currently hidden but we are considering integrating it into the technical room. Underfloor heating with heat pump. Photovoltaic system is also installed (west side).
What Is the Most Important / Fundamental Question About the Floor Plan in 130 Characters?
See above
Floor plan of a house with living/dining area, kitchen, hallway, guest room, utility room, shower/WC, garage.
Upper floor plan: master bedroom, 2 kids’ bedrooms, bathroom, study, hallway.
Architectural section of a two-story house with staircase, interior, and dimension lines.
Modern two-story house with white facade, black roof, large windows, and balconies.
White modern single-family house with grey gable roof and large windows.
Two-story house with white facade, grey gable roof, and integrated garage.
Modern white single-family house with dark gable roof, large windows, and garage.
s_mhofma
26 Feb 2023 15:03
Well, you’re quite a character. You come along in post #45 casually like a cheerful whistler with a huge bombshell of information: that your plot is entirely surrounded by kink lines and forms the planning area MI3 alone, with probably a residential area WA1 bordering two plots above the plan (and behind that, a WA2), the rear ten meters of your plot lie outside the building boundary (so much for your dream of a pool), and on the neighbor’s left side there’s even a special building window Ga/Cp that reaches right up to your boundary. Then, on the left side of your plot and top side of neighbor 315/2, you see a three-meter-wide (about 10 feet) corner—just missing the fact that a GFL right might be imposed there. If Katja thinks that the development plan wasn’t really considered here, that’s putting it very mildly!
No, you can’t “still evaluate whether the windows make sense.” I don’t understand how any architect can arbitrarily rotate the house and change the staircase; that seems like a clear reason to terminate their contract. Where did you even find this person?
Apart from the fact that after so many crucial pieces of information were thrown in so late, I don’t even feel like analyzing the floor plan: the architect definitely needs to be replaced, and with a good architect, you always start fresh—without dragging the “carrier virus old plan” into the work with them. At most, the draft by @saralina87 can be brought into the discussion—but only after your new architect’s first preliminary draft! I don’t have an architect “on hand” in the HP circle yet, but I’ll gladly look for one for you.
I’m really sorry, but I don’t understand half of that.
What does all of that mean exactly?
Sorry, we were recommended an architect here in Stuttgart. Of course, I expect that they will deal with the development plan. A layperson would assume that, right?
And yes, this is the first house we’re building.
I understand that the plot is not ideal. But I don’t understand the other things mentioned above. Could you please explain that again in a different way?
Thank you
K a t j a26 Feb 2023 16:47
The plot itself is not unreasonable. The zoning plan might be a bit strict, but that’s the trade-off for living in the city.
Excerpt:
"...Building line along Nibelungenstraße as well as the building line along Heinrichstraße south of Hagenstraße. Crossing the building line or setting back behind the building line is not permitted here."
So setbacks are indeed not allowed on Nibelungenstraße.
@11ant
I wonder if this also fixes the shape of the main building? What if I want to build a three-gable house or a dwarf house? Would the third gable then be considered a setback?
Is a single-story building on the building line, with a two-story section behind it, also considered a setback?
It seems to me that the interpretation of the zoning plan is quite vague and helps the city reject anything they find visually unappealing. If you look at numbers 101 and 103, strictly speaking, you could also call that an L-shaped setback. So can it be assumed that you could build something similar here—just smaller?
Too bad Dimeto isn’t around.
K a t j a26 Feb 2023 16:52
@s_mhofma What is your budget?
s_mhofma
26 Feb 2023 17:09
500,000 euros for the house without a basement.
kbt09
26 Feb 2023 17:42
@K a t j a, @11ant ... you’ve now taken a look at the development plan. I’m not very familiar with it. Is it possible to plan for 2 full stories now? Or does it require a workaround like having knee walls over 180cm (6 feet) or something similar? Thanks 🙂
K a t j a26 Feb 2023 18:30
[QUOTE="kbt09, post: 620319, member: 18068"]
@K a t j a, @11ant ... you have now looked into the development plan. I'm not very familiar with it. Is it possible to plan for 2 full stories? Or do you need a workaround like a knee wall over 180cm (6 feet) or something? Thanks 🙂
• maximum permitted eave height = 7 m (23 feet)
• maximum permitted ridge height = 12 m (39 feet)
... as far as I could read.
That should easily allow for 2 stories.
