ᐅ Floor Plan Optimization – Semi-Detached House Approximately 150 sqm
Created on: 19 May 2022 16:40
KleinUndFein
I’m new here and would appreciate your ideas. We are planning a 150 sqm (1,615 sq ft) semi-detached house and are looking for the optimal floor plan.
Development Plan/Restrictions
The building envelope is used to its full extent.
Builders’ Requirements
- As clever a floor plan as possible
- The house will be occupied by two adults and two children (4 and 6 years old)
- The ground floor and upper floor should be able to be lived in separately (aging in place)
- No overly extravagant or expensive features should be used
- Basement with a technical room is available
- Prefer architectural style and conservative construction methods
- Open kitchen, but more of a kitchen-living area. The “living/media area” should be part of the kitchen-living space
- Are there better ways to use the space and are the room sizes suitable for normal use?
- Does the layout suit a family and two living units for the future?
WilderSueden schrieb:
On the one hand, you can’t put a double bed in the narrow guest room on the ground floor Actually, you can.
The room is almost exactly the same size as my parents’ bedroom, and the door is in the same position. With a double bed and a wardrobe (on the door side), it doesn’t feel cramped at all... I was quite surprised how small the room actually is when I finally had a floor plan in my hands.
I see more of an issue on the upper floor... Where would the living room go there?
Kreisrund20 May 2022 08:30I’m curious about what you mean in the questionnaire by “as clever a floor plan as possible.” What do you consider clever in this context?
KleinUndFein20 May 2022 08:4911ant schrieb:
You’re speaking in riddles, like here before:
Even in Klein-Krotzenburg, a semi-detached house is a semi-detached house, and a semi-detached house is not a semi-detached house (???)What do you call it when 60% of a semi-detached house has stood since the 19th century, and we are rebuilding the other 40%? To me, it is a semi-detached house, but not a typical one?
KleinUndFein20 May 2022 09:01SoL schrieb:
Since the original poster is not providing any real information, I’ll keep it to the main point: the floor plan is a complete mess!
I’ll explain why once all the information is available. It’s a piecemeal approach and so on...Thanks for reading and for the general comment. Since we are not very happy, I wrote here.
We are not taking a piecemeal approach. We promised the sellers (the mayor’s parents) to stick to the original dimensions – that was important to them. We didn’t think the measurements were that bad. It’s just a rather square layout for a semi-detached house.
KleinUndFein20 May 2022 09:03Kreisrund schrieb:
I’m curious about what you mean in the questionnaire by “as clever a floor plan as possible.” What does clever mean to you in this context?Above all, accessibility and the sequence of the rooms. Efficient use of space. Apart from the upstairs hallway, we have been quite happy so far.Originally, we wanted an open-plan kitchen and living area downstairs and a small media room. If necessary, the guest room will have to serve as a retreat.
