Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
pagoni2020
17 Nov 2021 10:09
Tom1978 schrieb:
Yes, I would have. But since he still has a lot to do on our property, I'd rather bite the bullet. We actually have a good relationship that I don’t want to ruin over something like this. He has already done some extra work for free and promised a few things as well. So it’s not that bad...
That’s a healthy attitude.
You will encounter more rough edges with both the project and the people involved in your build, so it’s better to look for solutions instead of trying to force things through by pressure. For me, it’s always important to determine whether an issue arises from laziness or ignorance or if it’s just an accident. Thinking about each situation often leads to ideas that turn out to be better or at least good.
The tradespeople on my project also ordered materials late and were surprised, even though it was foreseeable for us as clients that deliveries would be tight. Save your energy for the truly important matters.
Nida35a17 Nov 2021 10:57
For our hammerhead lot, the construction access road had to be placed underneath the current driveway.
The civil engineer / landscaper / paver removed 30–40 cm (12–16 inches) of topsoil and filled and compacted it with recycled material; this then served as the construction access road.
All pipes and empty conduits were already installed underneath.
Then the house was built and all connections were made to the utilities.
After that, the terrace and cistern were constructed, edges were installed, recycled material was leveled off, paving was done, and topsoil was spread—always working from the back to the front, all using a wheel loader.
The paved path is now suitable for vehicles up to 10 tons (11 tons), e.g., moving vans, motorhomes, tradesmen’s vans.
So plan accordingly with and for the civil engineer,
and the project manager was told: if a pool is planned, do it now.
driver55
17 Nov 2021 12:22
Tom1978 schrieb:
General question. What is your post supposed to convey? Bad mood, trolling, or just venting frustration? 😎
No, neither 1, 2, nor 3.
You usually say you have almost everything under control, and now it’s failing over a simple “concrete block.” This and the accessories could have been ordered ages ago and stored at your place “in the woods.” If not, then you just need to find another source. I can’t imagine they’re sold out “worldwide.”
If you don’t install it now, you probably won’t do it later either. Additional services/costs because of extra effort if the “house is already built” (you won’t get around the house anymore? Crane needed?).
Being a builder is basically like having a second full-time job. 😉
Tom1978
17 Nov 2021 12:40
driver55 schrieb:
You always say here that you have everything under control...
Really? Where exactly? We are just at the beginning...
And no, that couldn’t have been ordered at the start. If you are a regular reader, you hardly could have missed the tree removal. And a concrete block right in the middle of the property that needs to be moved wouldn’t exactly make the company jump for joy.
Being a client also means making compromises and not trying to push everything through by force. Besides, it’s not a full-time job; otherwise, no one could afford to give up their job for a year. It does take up a lot of time, admittedly, and you have to think about and organize many things. But it’s all doable.
DennisW
17 Nov 2021 14:54
Are the development costs so high because your house is located relatively far back?
Tom1978
17 Nov 2021 15:24
DennisW schrieb:
Are the utility connection costs so high because your house is relatively far back?
I think so. The house is 16m (52 feet) from the street. But I’m not sure if the €9,800 for the house connections: water + wastewater and construction water is a lot? My planning was: house connections for water + wastewater + electricity = €18,500. Construction water: €1,500. Temporary construction electricity I estimated at €2,000.
