ᐅ Is it possible to design an open-plan kitchen with special custom features in only 29 square meters?
Created on: 20 Dec 2020 18:58
knalltüte
I would like to reconsider my current plans for the open-plan kitchen, bathroom, and bedroom, and use the collective intelligence of this forum for inspiration.
Over the past few months/during the construction, my priorities have shifted slightly (preferably furnishing with higher-quality items right away, not taking existing furniture with me), so I now require professional help especially with the kitchen/dining corner layout (this was planned from the start). On-site appointments at kitchen studios will likely follow as soon as possible. But perhaps I can already find suitable ideas here.
My desired kitchen features (designed for myself, maximum for two people):
Sink + dishwasher (preferably the dishwasher installed at “mid-height”). The sink location is roughly fixed due to the existing wastewater pipe options.
An oven with pyrolytic self-cleaning, nothing special otherwise. The oven can be installed “low” (as there is probably only one built-in spot at “mid-height”). I don’t need a microwave (not even one integrated into the oven).
The cooktop can be induction, possibly with a downdraft vent (preferably from Berbel, as I like their cleaning and technology best). It should not be too wide; do models around 60cm (24 inches) wide exist?
Alternatively, I am considering a two-burner gas cooktop combined with a teppanyaki grill. I would even prefer if this combination could be paired with a recirculation hood or downdraft vent—is that possible? The gas supply would come from a bottled source in the technical room.
My wishes for the cooktop include front-facing knobs (instead of touch control), and easy cleaning (with gas, probably only “Pitt Cooking” works).
I want a refrigerator with one or two freezer drawers or an integrated small freezer compartment. I would prefer the fridge and dishwasher to be integrated into a wall-mounted cabinet.
I need about 60-80cm (24–31 inches) of free countertop space for food preparation, plus about 40cm (16 inches) for appliances (only a small portafilter espresso machine + grinder). All other appliances should be stored in cabinets or drawers. The kitchen overall should not take up too much space and should appear clean, elegant, and floating. (I really like the design of many Bulthaup B3 wall-mounted kitchens.)
Directly adjacent to the kitchen, I want a comfortable counter/dining area mostly for myself, but it should fit up to four people (even if that is a bit tight), preferably with a view towards the terrace/pool/south-facing windows.
It would be nice to have the option to expand the dining area significantly for larger groups when “social gatherings” become possible again.
I am aware that the actual living area (entire apartment excluding the terrace) is only 59m² (635 square feet). Are my wishes even remotely feasible?
I certainly don’t expect space for gatherings with 20 people. My idea would be to compress the living area and add another table to the existing dining corner to significantly enlarge it.
What doesn’t exist in suitable space-saving dining furniture can of course be custom-built ;-)
I am very open to “wow effect” suggestions. I just don’t have the creative knack for this myself.
There is no fixed budget planned for this. Everything so far has always changed spontaneously, so why not here?
Since this is an open-plan kitchen, here is my (unfinalized) wish list for the TV/living area as well.
A comfortable but small corner sofa for 1–2 people. It should also serve as a possible sleeping space.
A small coffee table (height-adjustable) with multiple functions (dining, mini workspace).
Possibly a small side table of about 35cm (14 inches) diameter.
The TV will be integrated into the wall (I left a suitably sized recess for this). Therefore, I don’t need a lowboard or similar. All equipment including cables (except for the TV) will be hidden.
If there is still some space on the sofa side (unlikely), I could imagine a small (mini) wall-mounted sideboard. I like the design of the Interlübke Cube models.
Comments like “that’s something you do before floorplanning and construction” are a bit late by now :p
Grundriss eines Apartments mit Bad, Küche, Schlafen, Wohnen, Eingang, TV.
21 Dec 2020 22:03
I also considered a mobile kitchen island, but earlier I used a kitchen planner and it felt quite tight, even without the stove. I started fairly conservatively with two tall cabinets by the utility room. With a depth of 60cm (24 inches), that leaves 2.70m (8 feet 10 inches), and in the corner there’s only 59cm (23 inches)... which means 2.40m (7 feet 10 inches) for everything plus a shelf bonus or a narrow pull-out cabinet for dish towels. Or a 37/40cm (15/16 inches) cabinet by the window.
As a result, the stove will probably have to stand on something fixed... like an island that can be adjusted within the room, for example with a fold-down table or something similar.
When men plan houses... the kitchen often gets neglected 🙄
haydee
22 Dec 2020 08:10
My hope was that the stove would still fit into the fixed kitchen line, and the mobile unit would then only provide storage and workspace.
knalltüte
22 Dec 2020 08:22
Hello, I took some measurements this morning. It is indeed 65cm (25.6 inches) from the party wall to the window reveal, just as "ordered." So the spot mentioned in the first post where it says 59cm (23.2 inches) ...
hampshire
22 Dec 2020 08:34
When men plan houses ... the kitchen always gets neglected 🙄
Ridiculous stereotype. Discrimination apparently goes both ways 😉
E
evelinoz
22 Dec 2020 09:22
@superzapp, sorry, the way you're approaching your kitchen planning is quite chaotic. It won’t work like that. Please upload your pictures and an accurately dimensioned ground floor plan. It will be much easier to create a plan than trying to find relevant information for your kitchen across 30 posts.
22 Dec 2020 09:35
hampshire schrieb:
Stupid prejudice. Discrimination obviously works both ways.
Yes, and it’s best when you have the example clearly in black and white right in front of you.
I think the requirements and the drawing should be pinned.
