ᐅ Structural opening size for the door to the utility room
Created on: 29 Nov 2019 17:29
O
Oakland
How wide does the rough opening for the utility room door need to be to allow both the boiler and hot water tank to fit through? This concerns a single-family house.
readytorumble
30 Nov 2019 10:08
I also agree with the architect. You should trust him; he likely has more experience than you do.
opalau30 Nov 2019 10:12
Then just make the door 88.5cm (35 inches).
guckuck2
30 Nov 2019 10:33
opalau schrieb:
Then just make the door 88.5.
I assume the OP isn’t concerned about saving €30 by having a smaller door leaf if they don’t want an 88.5 (35 inches) door.
I guess the 88.5 (35 inches) door simply doesn’t fit the design or floor plan.
opalau30 Nov 2019 12:20
guckuck2 schrieb:
It’s probably not about saving 30€ on the smaller door leaf for the original poster if he/she doesn’t want the 88.5cm (35 inches) door.
I assume the 88.5cm (35 inches) door doesn’t fit the design or floor plan.
That may be the case. However, I can hardly imagine many situations where the additional 12.5cm (5 inches) wouldn’t be possible at all. It’s generally not a bad idea to avoid a narrow door in the utility room anyway.
