Created on: 27 May 2019 10:48
goalkeeper
Whether the front door is flush with the left side or aligned with the lower window on the right is less interesting to me when looked at individually. What’s much more important is how the neighboring windows disrupt the overall facade view in the panorama. On the photo, I only see half of a detached house (at first, I wondered where the other half was).
It will look quite odd in the row of houses if every house has different window shapes, sizes, colors, and positions (plus facade color), and the front door placement also varies.
Zaba12 schrieb:
The more interesting question is how the neighboring windows will ruin your facade view in the panorama. It will remain just this one half—some cynical voices even say "at all"—but "relatively" it will be the same elsewhere: middle houses are usually built recessed, while the houses on the outer sides will be the ones to actually align in the building line.
goalkeeper13 Nov 2019 22:3011ant schrieb:
This will remain just one half – some critics might say “not at all,” but “relatively” it will be the same otherwise: mid-terrace houses are built set back, and only the end-terrace neighbors will align with the building line. That’s exactly how it will be – a small detached unit that looks like a cut-off piece of cake.
goalkeeper15 Nov 2019 21:40So... tomorrow the rest of the gable will be completed and the guest bathroom window will be relocated. Then work on the roof framework should continue on Monday.
Meanwhile, Viebrockhaus has started the foundation slab for its basement, and our supposed middle house neighbor apparently has a notary appointment on Thursday.
goalkeeper15 Nov 2019 22:38kaho674 schrieb:
Are you planning to raise the entire garden area? Or will there be a small slope or staircase?Everyone complete!
