ᐅ Will our house be too dark? Opinions on the floor plan
Created on: 16 Feb 2015 01:30
Trillian78
Trillian78
16 Feb 2015 01:30
we have completed the preliminary planning and would like to get some opinions, especially regarding natural light and windows.
The guest WC window is planned to face north, and the floor-to-ceiling window in the upstairs bathroom will definitely be removed.
The office on the ground floor is now intended to become a utility room, and the pantry will be converted into a cloakroom.
For this reason, the office will be moved to the 15m² (160 sq ft) basement room, as it is rarely used. However, I have serious concerns that the basement will become too dark. Since there will be a terrace on the south side, no light wells can be installed there. The large basement room is actually intended for social gatherings. The light well will still serve as an outdoor staircase. This means there will be no additional windows in that room, and the future office in the basement will also be quite dark because the garage restricts the window size.
I have similar concerns about the kitchen, which only has a window on the north side due to the garage.
The same applies to the bedroom. There is a window facing east, but it is directly under the garage roof. The narrow window on the north side will be removed as we do not like it. I think a skylight is necessary here. What do you think? Should we also consider adding skylights to the south-facing children’s rooms?
Does anything else stand out to you at first glance as potentially problematic?
Thanks for your feedback!
Yellow detached house with dark slate roof, glass front and terrace on green lawn.
Two-story yellow detached house with dark pitched roof, glass entrance front and paved driveway.
Attic floor plan: bathroom, sleeping/dressing, hallway, child 1, child 2, conservatory.
House floor plan: dining/living, kitchen, office, WC, hallway, garage.
Basement floor plan with hobby room, room 5, HAR/utility room, cellar 1, hallway and foundations.
Mycraft16 Feb 2015 06:04
Oh man, the whole appearance is just terrible... I would say this is a case of going down the wrong path...
Koempy16 Feb 2015 06:30
The hallway downstairs is very awkwardly shaped, and the staircase basically doesn't fit there at all. The kitchen could indeed end up too dark. I would suggest having a second floor plan designed.
wrobel16 Feb 2015 07:02
Let me add something...
Why is there a shaft about 80cm (31.5 inches) wide in the living room ceiling?
And imagine carrying a basket of laundry to the closet area in the bedroom.
The space between the closets is also too narrow.
Where is the wardrobe?
Olli
Legurit
16 Feb 2015 07:27
Ground floor lighting is okay. Bedrooms for children might be too dark. What is the ratio A (area) of the rough window opening to the living area in the children's bedrooms?
kbt09
16 Feb 2015 07:52
What is the sill height of the windows in the bathroom and bedroom here? Also, what is the planned knee wall height?
Then the staircase... 14 risers? What is the rise/run measurement of the stairs?
The office in the basement... is it mainly for file storage or actually used for working from home?
Is there already collaboration with an architect or similar?
