ᐅ Why do some Ikea Metod cabinet doors not close flush?
Created on: 26 Sep 2021 19:12
henrypo
While assembling my Ikea Metod cabinets, I noticed that some of the doors do not close flush. The edges either protrude slightly or cannot be adjusted to close completely clean and seamless. My question is: why do some Ikea Metod doors not close flush, even though the hinges are supposed to be adjustable? Are there known issues with the manufacturing, assembly, or possible tolerances that prevent this? I would appreciate detailed tips and experiences, as I want to achieve the most precise appearance possible.
henrypo
27 Sep 2021 14:45
Kinbu schrieb:
Material warping due to temperature or moisture
That sounds interesting; I hadn’t really considered that before. Do you think that slight moisture changes in the room can actually be enough to cause the doors to warp slightly and prevent them from closing flush? I have my Ikea Metod cabinet in a kitchen where there are definitely fluctuations in temperature and humidity.
INGRID34
27 Sep 2021 19:07
henrypo schrieb:
I have my Ikea Metod cabinet in a kitchen where there are quite some fluctuations in temperature and humidity.
Yes, that is definitely possible. Engineered wood products, even if veneered, can react to moisture. In a kitchen with changing humidity levels, this is a factor that is often underestimated. If the changes are minor, you can still adjust the hinges. During humidity peaks, the doors may temporarily warp.
rimole
27 Sep 2021 21:00
If doors are not closing flush, I would first check the following:
- Are the hinges installed correctly?
- Are all screws tightened properly?
- Are the doors aligned correctly on the hinges?
If everything is in order, only fine adjustment of the hinges will help.
praWarre69
28 Sep 2021 07:18
henrypo schrieb:
Why do some Ikea Metod doors not close flush, even though the hinges can actually be adjusted?
In addition to warping and tolerances, it may also be that the hinge screws were tightened too much or unevenly during installation. Over-tightening can slightly shift the position.
If you feel like it, you can carefully loosen the screws a little with a small screwdriver, realign the door, and then tighten them again. But be careful not to overtighten, or the screws might strip!
With a bit of patience, it usually works out in the end. And hey, a little attention to detail is what makes the Ikea hack perfect 🙂
